My domain is: proxim.khas.dev
certbot --nginx -d proxim.khas.dev
Requesting a certificate for proxim.khas.dev
Domain: proxim.khas.dev
Detail: 95.217.226.251: Invalid response from https://proxim.khas.dev/?url=/.well-known/acme-challenge/ofFBbu-c-GqCUNKGuiMNCn-hamnx4TiikQN4B9piH3M: "<!doctype html>\n<!--[if IE 8 ]><html lang=\"en\" class=\"ie ie8 lte9 lte8 no-js\"><![endif]-->\n<!--[if IE 9 ]><html lang=\"en\" class="
nginx version: nginx/1.18.0
Debian GNU/Linux 11 (bullseye)
or certbot-auto --version
if you're using Certbot):
certbot 1.28.0
My Nginx configuration:
Default
# cat /etc/nginx/sites-available/default
listen 80 default_server;
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
Proxim
cat /etc/nginx/sites-available/proxim.khas.dev
listen 80;
listen [::]:80;
root /var/www/proxim/html;
server_name proxim.khas.dev;
location ~ /.well-known {
root "/var/www/html";
allow all;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
proxy_pass https://localhost:8006;
proxy_buffering off;
client_max_body_size 0;
proxy_connect_timeout 3600s;
proxy_read_timeout 3600s;
proxy_send_timeout 3600s;
send_timeout 3600s;
Sites Enabled directory:
# ls -al /etc/nginx/sites-enabled/
proxim.khas.dev -> /etc/nginx/sites-available/proxim.khas.dev
Nginx Status
# systemctl status nginx.service
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-06-28 23:51:56 CEST; 12min ago
Docs: man:nginx(8)
Process: 1560165 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 1560166 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 1560167 (nginx)
Tasks: 13 (limit: 77040)
Memory: 11.2M
CPU: 82ms
CGroup: /system.slice/nginx.service
├─1560167 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
├─1560781 nginx: worker process
├─1560782 nginx: worker process
├─1560783 nginx: worker process
├─1560784 nginx: worker process
├─1560785 nginx: worker process
├─1560786 nginx: worker process
├─1560787 nginx: worker process
├─1560788 nginx: worker process
├─1560789 nginx: worker process
├─1560790 nginx: worker process
├─1560791 nginx: worker process
└─1560792 nginx: worker process
Jun 28 23:51:56 proxim systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 28 23:51:56 proxim systemd[1]: Started A high performance web server and a reverse proxy server.
The question is why Certbot is trying to get the certificate over https? If https is not currently available? And unfortunately I can't figure out how it gets to https. Nowhere in my configurations can I find a redirect or anything else.
