pd.funkysalamander.com
sudo certbot --nginx
http-01 challenge for pd.funkysalamander.com
Using default address 80 for authentication.
2019/05/26 10:55:04 [notice] 2878#2878: signal process started
Waiting for verification…
Challenge failed for domain pd.funkysalamander.com
2019/05/26 10:55:17 [notice] 2881#2881: signal process started
Domain: pd.funkysalamander.com
Type: connection
Detail: Fetching
http://pd.funkysalamander.com/.well-known/acme-challenge/j7rot6IpbNeccJ2WBlkyzcmG0mhCeGN-LuS5VLaOrwA:
nginx 1.16.0-1
Arch Linux
Self
Depends on what you mean: DNS Controlled at FastMail
or certbot-auto --version
if you’re using Certbot):
0.34.2
Additional Information:
-Using ddclient for dynamic DNS through nsupdate.info
-The FastMail DNS Control Panel has a single ‘A’ record for mail.funkysalamander.com pointing to the FastMail server’s IP address. There is no other ‘A’ record.
-The FastMail DNS Control Panel has a CNAME record for pd.funkysalamander.com pointing to the ddclient dynamic DNS domain.nsupdate.info
-The LANs router has both ports 443 & 80 forwarded to the VM running nginx
$ dig pd.funkysalamander.com returns first its CNAME pointing to the domain.nsupdate.info, then an ‘A’ record from domain.nsupdate.info to the correct public dynamic IP address on the WAN side of the router.
