papaya.moe
certbot --nginx
Enter email address (used for urgent renewal and security notices) (Enter âcâ to
cancel): g@gmail.com
From cffi callback <function _verify_callback at 0x757cc540>:
File â/usr/local/lib/python3.5/dist-packages/OpenSSL/SSL.pyâ, line 309, in wrapper
_lib.X509_up_ref(x509)
AttributeError: module âlibâ has no attribute âX509_up_refâ
An unexpected error occurred:
File â/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.pyâ, line 417, in wrap_socket
cnx.do_handshake()
File â/usr/local/lib/python3.5/dist-packages/OpenSSL/SSL.pyâ, line 1915, in do_handshake
self._raise_ssl_error(self._ssl, result)
File â/usr/local/lib/python3.5/dist-packages/OpenSSL/SSL.pyâ, line 1647, in _raise_ssl_error
_raise_current_error()
File â/usr/local/lib/python3.5/dist-packages/OpenSSL/_util.pyâ, line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [(âSSL routinesâ, âtls_process_server_certificateâ, âcertificate verify failedâ)]
File â/usr/lib/python3/dist-packages/urllib3/connectionpool.pyâ, line 594, in urlopen
chunked=chunked)
File â/usr/lib/python3/dist-packages/urllib3/connectionpool.pyâ, line 350, in _make_request
self._validate_conn(conn)
File â/usr/lib/python3/dist-packages/urllib3/connectionpool.pyâ, line 837, in validate_conn
conn.connect()
File â/usr/lib/python3/dist-packages/urllib3/connection.pyâ, line 323, in connect
ssl_context=context)
File "/usr/lib/python3/dist-packages/urllib3/util/ssl.py", line 324, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File â/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.pyâ, line 424, in wrap_socket
raise ssl.SSLError(âbad handshake: %râ % e)
ssl.SSLError: (âbad handshake: Error([(âSSL routinesâ, âtls_process_server_certificateâ, âcertificate verify failedâ)],)â,)
File â/usr/lib/python3/dist-packages/requests/adapters.pyâ, line 423, in send
timeout=timeout
File â/usr/lib/python3/dist-packages/urllib3/connectionpool.pyâ, line 624, in urlopen
raise SSLError(e)
requests.packages.urllib3.exceptions.SSLError: (âbad handshake: Error([(âSSL routinesâ, âtls_process_server_certificateâ, âcertificate verify failedâ)],)â,)
requests.exceptions.SSLError: (âbad handshake: Error([(âSSL routinesâ, âtls_process_server_certificateâ, âcertificate verify failedâ)],)â,)
nginx
Raspbian
Self hosted
I can login to a root shell on my machine (yes or no, or I donât know):
Yes I can login with the root account.
Iâm using a control panel to manage my site (no, or provide the name and version of
the control panel):
No I am logged directly into the machine
or certbot-auto --version
if youâre using Certbot):
certbot 0.31.0
