Certbot failed to authenticate some domains. Timeout during connect (likely firewall problem)
My domain is: zlmedia.grasp.deals
raphy@raohy:~$ sudo certbot --nginx -d zlmedia.grasp.deals -d www.zlmedia.grasp.deals
Requesting a certificate for zlmedia.grasp.deals and www.zlmedia.grasp.deals
  Domain: zlmedia.grasp.deals
  Type:   connection
  Detail: aa.aa.aaa.aa Fetching http://zlmedia.grasp.deals/.well-known/acme-challenge/hzEtwSgJk_B1Gk83dtRk6yX1pEfN8ezjpmKtbDUis1o: Timeout during connect (likely firewall problem)
  Domain: www.zlmedia.grasp.deals
  Type:   dns
  Detail: DNS problem: NXDOMAIN looking up A for www.zlmedia.grasp.deals - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.zlmedia.grasp.deals - check that a DNS record exists for this domain
nginx :
raphy@raohy:~$ sudo systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
     Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; preset: enabled)
     Active: active (running) since Fri 2025-11-21 15:55:04 CET; 1h 14min ago
       Docs: man:nginx(8)
    Process: 152868 ExecReload=/usr/sbin/nginx -g daemon on; master_process on; -s reload (code=exited, st>
   Main PID: 145368 (nginx)
      Tasks: 9 (limit: 38346)
     Memory: 6.6M (peak: 14.6M)
        CPU: 291ms
     CGroup: /system.slice/nginx.service
             ├─145368 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
             ├─153261 "nginx: worker process"
             ├─153262 "nginx: worker process"
             ├─153263 "nginx: worker process"
             ├─153264 "nginx: worker process"
             ├─153265 "nginx: worker process"
             ├─153266 "nginx: worker process"
             ├─153267 "nginx: worker process"
             └─153268 "nginx: worker process"
nov 21 15:55:04 raohy systemd[1]: Starting nginx.service - A high performance web server and a reverse pro>
nov 21 15:55:04 raohy systemd[1]: Started nginx.service - A high performance web server and a reverse prox>
nov 21 16:31:53 raohy systemd[1]: Reloading nginx.service - A high performance web server and a reverse pr>
nov 21 16:31:53 raohy nginx[150831]: 2025/11/21 16:31:53 [notice] 150831#150831: signal process started
nov 21 16:31:53 raohy systemd[1]: Reloaded nginx.service - A high performance web server and a reverse pro>
nov 21 16:52:05 raohy systemd[1]: Reloading nginx.service - A high performance web server and a reverse pr>
nov 21 16:52:05 raohy systemd[1]: Reloaded nginx.service - A high performance web server and a reverse pro>
nov 21 16:52:05 raohy nginx[152868]: 2025/11/21 16:52:05 [notice] 152868#152868: signal process started
raphy@raohy:~$ sudo nano /etc/nginx/sites-available/zlmedia.grasp.deals :
        listen 80;
        listen [::]:80;
        server_name zlmedia.grasp.deals;
        root /var/www/zlmedia.grasp.deals;
        index index.html;
                try_files $uri $uri/ =404;
raphy@raohy:~$ ls -lah /etc/nginx/sites-enabled/ | grep zl
lrwxrwxrwx 1 root root   46 nov 21 16:51 zlmedia.grasp.deals -> /etc/nginx/sites-available/zlmedia.grasp.deals
My web server is: nginx version: nginx/1.24.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 24.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
raphy@raohy:~$ sudo ufw status
Status: active
To                         Action      From
6443/tcp                   ALLOW       Anywhere
10250/tcp                  ALLOW       Anywhere
80                         ALLOW       Anywhere
Nginx Full                 ALLOW       Anywhere
6443/tcp (v6)              ALLOW       Anywhere (v6)
10250/tcp (v6)             ALLOW       Anywhere (v6)
80 (v6)                    ALLOW       Anywhere (v6)
Nginx Full (v6)            ALLOW       Anywhere (v6)
What am I doing wrong and/or missing? How to make it work?
Hello @raphael10-collab, welcome back. :slightly_smiling_face:
Using the online tool Let's Debug yields these results
For zlmedia.grasp.deals - https://letsdebug.net/zlmedia.grasp.deals/2628688
And for www.zlmedia.grasp.deals - https://letsdebug.net/www.zlmedia.grasp.deals/2628687
There are different error for www.zlmedia.grasp.deals there simply is no IP Address.
And for zlmedia.grasp.deals Ports 80 & 443 are filtered meaning that from the Public Internet the site is not accessible.
Best Practice - Keep Port 80 Open
$ nmap -Pn -p80,443 zlmedia.grasp.deals
Starting Nmap 7.94SVN ( https://nmap.org ) at 2025-11-21 09:00 PST
Nmap scan report for zlmedia.grasp.deals (81.56.45.51)
Host is up.
rDNS record for 81.56.45.51: bny92-3_migr-81-56-45-51.fbx.proxad.net
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 5.07 seconds
Hi @Bruce5051 . Thank you for helping out.
I guess I have to open the ports on the ISP side
Basically yes; but it could also be your router or firewall(s) if the machine is on your premises.
And add DNS IP Address Record(s) (i.e. A Record for IPv4 and AAAA Record for IPv6, you can have both but only one is needed for the HTTP-01 challenge) for www.zlmedia.grasp.deal if you wish to use that name too.
