Certbot failed to authenticate some domains (authenticator: nginx) while using playit.gg to tunnel pteradactyl panel website
My domain is: serverpanel.obsidiusnet.au
I ran this command: certbot certonly --nginx -d staffpanel.obsidiusnet.au
Requesting a certificate for staffpanel.obsidiusnet.au
  Domain: staffpanel.obsidiusnet.au
  Type:   unauthorized
  Detail: 2606:4700:20::ac43:4844: Invalid response from https://playit.gg: "<!DOCTYPE html><html lang=\"en\"><head><meta charSet=\"utf-8\"/><meta name=\"viewport\" content=\"width=device-width,initial-scale=1\"/>"
My web server is (include version): nginx/1.24.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: Self host
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
I am using playit.gg to tunnel pteradactyl panel. I am following the instructions on "Creating SSL Certificates" Creating SSL Certificates | Pterodactyl and whenever I run the command "certbot certonly --nginx -d staffpanel.obsidiusnet.au" I get the error above.
Hello @Grandalfwise, welcome to the Let's Encrypt community. :slightly_smiling_face:
Trying the HTTP-01 ACME Challenge gets redirected to https://playit.gg
$ curl -Ii http://staffpanel.obsidiusnet.au/.well-known/acme-challenge/sometestfile
HTTP/1.1 302 Moved Temporarily
Server: playit-cloud
Following the redirection to https://playit.gg, note the .well-known/acme-challenge/<TOKEN> doesn't get passed on in the redirection.
$ curl -k -Ii https://playit.gg
HTTP/2 200
date: Thu, 09 Jan 2025 04:26:31 GMT
content-type: text/html; charset=utf-8
vary: Accept-Encoding
last-modified: Thu, 09 Jan 2025 03:33:34 GMT
cache-control: max-age=1200
cf-cache-status: HIT
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=S6biKd6iFlVoYigLF%2FFBvzSqzQyI%2FoyPI36eWyRXlGspWiUBabSMoXihrCHupoy8NCg2WWCB%2Fhii8mP5U9VVJPRccnW17y7Mvd9qAplosSkY4Ii%2Fzzzx76eNaw%3D%3D"}],"group":"cf-nel","max_age":604800}
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 8ff1ab6d0f156c8a-SEA
server-timing: cfL4;desc="?proto=TCP&rtt=12476&min_rtt=11839&rtt_var=4343&sent=6&recv=8&lost=0&retrans=0&sent_bytes=3403&recv_bytes=777&delivery_rate=244615&cwnd=252&unsent_bytes=0&cid=0e951ab62b918723&ts=41&x=0"
Edit
Also the CNAME point to band-gg.gl.at.ply.gg which has 2 IP Addresses an IPv4 and an IPv6
both need respond the same.
$ nslookup staffpanel.obsidiusnet.au
Server:         127.0.0.53
Address:        127.0.0.53#53
Non-authoritative answer:
staffpanel.obsidiusnet.au       canonical name = band-gg.gl.at.ply.gg.
Address: 147.185.221.25
Address: 2602:fbaf:808:1::19
Hey @Bruce5051 thanks for the information. Do you have any idea's on how I can fix the problem of staffpanel.obsidiusnet.au redirecting to playit.gg instead of to the pterodactyl panel?
I was able to fix the problem by using the command: certbot -d example.com --manual --preferred-challenges dns certonly.
I can't automatically renew the ssl cert but it works.
