Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: ‐‐dry‐run
Maybe Certbot could error when it encounters any unicode in the arguments.
I would prefer if the forum didn’t use unicode hyphens, single and double quotes when converting from Markdown→HTML.
This isn’t the first and probably won’t be the last time this problem has happened. Most users have no idea how to use code blocks, and we end up with commands that get corrupted after they get posted .
