Certbot Error DNS problem: NXDOMAIN
Hi community
We are having some problems with certbot process, above i put all the details, as we read some similar problems looks like the problem is in our DNS Zone file, so i put the out fo this.
DNS ZOne file
@ 10800 IN A 217.70.184.38
blog 10800 IN CNAME blogs.vip.gandi.net.
imap 10800 IN CNAME access.mail.gandi.net.
pop 10800 IN CNAME access.mail.gandi.net.
smtp 10800 IN CNAME relay.mail.gandi.net.
webmail 10800 IN CNAME webmail.gandi.net.
www 10800 IN CNAME webredir.vip.gandi.net.
@ 10800 IN MX 50 fb.mail.gandi.net.
@ 10800 IN MX 10 spool.mail.gandi.net.
Full Domain name: facceso.org
OS Ubuntu 16.04 + nginx
Hosting provider Gandi.net
command line: certbort --nginx
Output:
1: www.faccesso.org
blank to select all options shown (Enter ‘c’ to cancel):1
tls-sni-01 challenge for www.faccesso.org
Waiting for verification…
Failed authorization procedure. www.faccesso.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for www.faccesso.org
    Domain: www.faccesso.org
    Type: connection
    Detail: DNS problem: NXDOMAIN looking up A for www.faccesso.org
We will appreciate any help.
Thanks
Looks like it’s just a typo. You say your domain is facceso.org which exists, but told certbot to issue a certificate for faccesso.org (note the extra s) which does not exist.
Beyond the typo, you’re probably going to have a different problem: you probably can’t get a certificate using TLS-SNI-01 validation when the website is pointing to a Gandi operated domain parking server, like it is now. You would probably have to change the A/AAAA/CNAME record(s) to point directly to your actual server.
Redirect services may or may not work with HTTP-01 validation, depending on how it’s set up.
You could always use DNS-01 validation, but i don’t know if Gandi has an API for automating that, or how many clients support it.
Indeed it was a typo, but also problems with DNS Zone file, so i edit it and now waiting.
Thanks, I will let you know
Indeed there were both erros. Thanks it is working just fine
