Update: I solved my own issue but leaving this here in case anyone else runs into the same thing (as I already typed it up). TL;DR: if you move your certbot config_dir you need to manually update the paths in the renewal/*.conf files.
Switched from snap to pip install of certbot. Presumably certbot version was updated at the time of change (I didn't note the pre-change certbot version). Now running certbot 5.6.0 via pip.
We use certbot to issue/renew certs (we manage that process externally and don't use the built-in renewal daemon because we need to know when the cert renews so we can restart/reload services that use the certs). We also don't use certbot to install any certs. We create our own symlinks outside of the certbot data dir pointing at the current cert. So we rely on predictable certificate paths on disk.
e.g. for --cert-name DOMAIN_NAME I expect to find the cert at <DATA_DIR>/live/DOMAIN_NAME/cert.pem. Since the certbot update the certificates are being generated in locations with index numbers like <DATA_DIR>/live/DOMAIN_NAME-XXXX/cert.pem. Of course this means our symlinks don't know where to point and we also can't easily check expiration because we don't know where to look for the files.
certbot certonly --cert-name
certbot certonly --webroot --webroot-path /var/www/DOMAIN_NAME --domains DOMAIN_NAME --non-interactive --key-type rsa --rsa-key-size 2048 --cert-name DOMAIN_NAME --config-dir /opt/certbot/data --server https://acme-v02.api.letsencrypt.org/directory --agree-tos --email it@DOMAIN_NAME
Requesting a certificate for DOMAIN_NAME
Certificate is saved at: /opt/certbot/data/live/DOMAIN_NAME-0005/fullchain.pem
Key is saved at: /opt/certbot/data/live/DOMAIN_NAME-0005/privkey.pem
This certificate expires on 2026-09-30.
Running certbot certificates reveals some possible underlying issues...
The following renewal configurations were invalid:
/opt/certbot/data/renewal/DOMAIN_NAME.conf
and
Renewal configuration file /opt/certbot/data/renewal/DOMAIN_NAME.conf produced an unexpected error: expected /opt/certbot/live/DOMAIN_NAME/cert.pem to be a symlink.
Maybe this is artifact of a certbot behaviour change and the right answer is just to blow away the data dir and start from scratch? The symlink bit is weird because checking the certbot data dir, none of the new certs are symlinks either.
Whatever the fix is, I need to apply this automatically across a lot of servers. Due to the nature of the problem and our setup, the automation has also run into a problem: because the certificate on the expected path is expiring soon and so we try to renew over and over which either creates new certs in unexpected paths or fails due to too many requests.
So I would prefer to fix the issue in place. e.g. fix any issues with the config and folder structure and delete unnecessary files/certs. If I blow away the certbot data directory, then we will have an SSL outage until certbot manages to retrieve a new certificate.
# certbot certificates --config-dir /opt/certbot/data
Renewal configuration file /opt/certbot/data/renewal/DOMAIN_NAME.conf produced an unexpected error: expected /opt/certbot/live/DOMAIN_NAME/cert.pem to be a symlink. Skipping.
Found the following certs:
Certificate Name: DOMAIN_NAME-0001
Serial Number: 5158013d0adf25251ebff3b43286ab67778
Key Type: RSA
Identifiers: DOMAIN_NAME
Expiry Date: 2026-09-28 14:41:43+00:00 (VALID: 84 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0001/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0001/privkey.pem
Certificate Name: DOMAIN_NAME-0002
Serial Number: 51c54c39132f0f3b2948ea9891b8463d538
Key Type: RSA
Expiry Date: 2026-09-28 14:56:36+00:00 (VALID: 84 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0002/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0002/privkey.pem
Certificate Name: DOMAIN_NAME-0003
Serial Number: 581a615a22214cadcba387faa2aec5eba23
Key Type: RSA
Expiry Date: 2026-09-28 15:06:41+00:00 (VALID: 84 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0003/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0003/privkey.pem
Certificate Name: DOMAIN_NAME-0004
Serial Number: 5f3ef2554f5f67c23ae56825288cc843e39
Key Type: RSA
Expiry Date: 2026-09-28 15:16:38+00:00 (VALID: 84 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0004/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0004/privkey.pem
Certificate Name: DOMAIN_NAME-0005
Serial Number: 57fbfe4c9bccf020130b95e270cff1ae72e
Key Type: RSA
Expiry Date: 2026-09-30 00:21:59+00:00 (VALID: 85 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0005/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0005/privkey.pem
Certificate Name: DOMAIN_NAME-0006
Serial Number: 6fe839960e9a72d9d4817c2471e7b294a5a
Key Type: RSA
Expiry Date: 2026-09-30 18:22:07+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0006/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0006/privkey.pem
Certificate Name: DOMAIN_NAME-0007
Serial Number: 63bde861c7c2460bc3da09b13809ec6c7a9
Key Type: RSA
Expiry Date: 2026-09-30 18:27:07+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0007/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0007/privkey.pem
Certificate Name: DOMAIN_NAME-0008
Serial Number: 6c6ad8bbd755378dc63839f48be8d168ab0
Key Type: RSA
Expiry Date: 2026-09-30 18:32:09+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0008/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0008/privkey.pem
Certificate Name: DOMAIN_NAME-0009
Serial Number: 6f4ea4bca6e684747ee43be5bd63046c70d
Key Type: RSA
Expiry Date: 2026-09-30 18:37:15+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0009/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0009/privkey.pem
Certificate Name: DOMAIN_NAME-0010
Serial Number: 6c2317b78785b505929c6d53fed26e987e5
Key Type: RSA
Expiry Date: 2026-09-30 18:42:06+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0010/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0010/privkey.pem
Certificate Name: DOMAIN_NAME-0011
Serial Number: 583688b82056dd82450ae307abb1d9c77df
Key Type: RSA
Expiry Date: 2026-09-30 21:52:11+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0011/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0011/privkey.pem
Certificate Name: DOMAIN_NAME-0012
Serial Number: 50e480de9dceaf1a73759708d4a21cfa8b1
Key Type: RSA
Expiry Date: 2026-09-30 21:57:11+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0012/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0012/privkey.pem
Certificate Name: DOMAIN_NAME-0013
Serial Number: 52ab38e9ab21239312692ff9435e7a0dd9a
Key Type: RSA
Expiry Date: 2026-09-30 22:07:10+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0013/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0013/privkey.pem
Certificate Name: DOMAIN_NAME-0014
Serial Number: 5691360e8ad99c0b4cb40935cda70b0639d
Key Type: RSA
Expiry Date: 2026-09-30 22:17:11+00:00 (VALID: 86 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0014/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0014/privkey.pem
Certificate Name: DOMAIN_NAME-0015
Serial Number: 57e3fea520e48ac9ae22f775f4c5bd674d0
Key Type: RSA
Expiry Date: 2026-10-02 07:32:28+00:00 (VALID: 87 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0015/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0015/privkey.pem
Certificate Name: DOMAIN_NAME-0016
Serial Number: 506e9299b08f97baaf0c4650c5f787c4f0b
Key Type: RSA
Expiry Date: 2026-10-03 17:07:47+00:00 (VALID: 89 days)
Certificate Path: /opt/certbot/data/live/DOMAIN_NAME-0016/fullchain.pem
Private Key Path: /opt/certbot/data/live/DOMAIN_NAME-0016/privkey.pem
Files in certbot data dir
# find /opt/certbot/data/ \( -type f -o -type l \) -exec ls -la {} \;
/opt/certbot/data/accounts/acme-v02.api.letsencrypt.org/directory/9bbbb15ffe1874814cd0810abc9449cd/private_key.json
/opt/certbot/data/accounts/acme-v02.api.letsencrypt.org/directory/9bbbb15ffe1874814cd0810abc9449cd/meta.json
/opt/certbot/data/accounts/acme-v02.api.letsencrypt.org/directory/9bbbb15ffe1874814cd0810abc9449cd/regr.json
/opt/certbot/data/keys/0000_key-certbot.pem
/opt/certbot/data/keys/0001_key-certbot.pem
/opt/certbot/data/keys/0003_key-certbot.pem
/opt/certbot/data/keys/0002_key-certbot.pem
/opt/certbot/data/csr/0002_csr-certbot.pem
/opt/certbot/data/csr/0003_csr-certbot.pem
/opt/certbot/data/csr/0000_csr-certbot.pem
/opt/certbot/data/csr/0001_csr-certbot.pem
/opt/certbot/data/live/README
/opt/certbot/data/live/DOMAIN_NAME/README
/opt/certbot/data/live/DOMAIN_NAME/privkey.pem -> ../../archive/DOMAIN_NAME/privkey20.pem
/opt/certbot/data/live/DOMAIN_NAME/chain.pem -> ../../archive/DOMAIN_NAME/chain20.pem
/opt/certbot/data/live/DOMAIN_NAME/cert.pem -> ../../archive/DOMAIN_NAME/cert20.pem
/opt/certbot/data/live/DOMAIN_NAME/fullchain.pem -> ../../archive/DOMAIN_NAME/fullchain20.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain16.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert15.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain17.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert20.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey17.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey19.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain18.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert18.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey15.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey20.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain15.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain20.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain18.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey16.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain19.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain17.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert19.pem
/opt/certbot/data/archive/DOMAIN_NAME/privkey18.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert16.pem
/opt/certbot/data/archive/DOMAIN_NAME/cert17.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain16.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain15.pem
/opt/certbot/data/archive/DOMAIN_NAME/chain20.pem
/opt/certbot/data/archive/DOMAIN_NAME/fullchain19.pem
solution
Posting this in case anyone else runs into the same problem.
I had moved the certbot data dir as part of the new setup when switching from snap to pip. Forgot about that "variable" when considering potential causes.
The .conf files in the DATA_DIR/renewal/ directory contain hard-coded absolute paths. When running certbot certonly or certbot certificates with the new DATA_DIR, it finds these config files and then looks on the hard-coded paths for the live (symlinks) and archive dirs. As the paths in the conf file are out of date, it does not find these and complains about the missing symlinks. So it sees the config file as invalid and needs to use a new cert-name to avoid collisions (either to avoid clobbering the renewal/CERT_NAME.conf file or the existing {live,archive}/CERT_NAME/ dir). So it adds the numbering on the end of the certname. Each time our own external renewal process runs with the original cert name the process happens again including collisions with the various numbering.
The solution is the fix the paths in the renewal/*.conf files and purge all the extra files with index numbers in renewal/ and live/ and archive/ dirs.
While this is a user-caused edge case, it would be nice if certbot logged when this was happening to make the root cause more obvious. e.g. Collision with cert-name _____ due to existing invalid config renewal/CERT_NAME.conf. Will attempt to use cert-name _____ instead.. Presumably the renewal live and archive dirs will always live in the same DATA_DIR/config_dir... so could also add support for using a placeholder/variable for $config_dir in the renewal .conf files to make it easier to move the directory (i.e. paths relative to config_dir rather than absolute paths).
Just an idea.
