hula-hoop.cz
/usr/local/bin/certbot-auto renew
Processing /etc/letsencrypt/renewal/hula-hoop.cz.conf
http-01 challenge for hula-hoop.cz
http-01 challenge for www.hula-hoop.cz
Attempting to renew cert (hula-hoop.cz) from /etc/letsencrypt/renewal/hula-hoop.cz.conf produced an unexpected error: Failed authorization procedure. hula-hoop.cz (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.hula-hoop.cz/.well-known/acme-challenge/XlBAZWnn-pVYD-VM8EHNT00uYwF8tCnY0DVwoDZQfH4: Connection refused, www.hula-hoop.cz (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.hula-hoop.cz/.well-known/acme-challenge/6hhKAXFBR_4XjcnMJShEUIEtc1Sj0q7MvReB1RgZuB8: Connection refused. Skipping.
/etc/letsencrypt/live/hula-hoop.cz/fullchain.pem (failure)
Domain: hula-hoop.cz
Type: connection
Detail: Fetching
Connection refused
Domain: www.hula-hoop.cz
Type: connection
Detail: Fetching
Connection refused
nginx/1.2.1
Debian 7.11
Linode
Yes
No
or certbot-auto --version
if you’re using Certbot):
certbot 0.31.0
This install and cronjob have been running happily for a few years. I recently upgraded certbot-auto
as another installation of mine got the email about TLS-SNI-01. I thought it just a question of time before I got that same email so preemptively upgraded. Now the cert is due for renewal, the process is failing.
I am pretty sure this must be something to do with the TLS-SNI-01/http-01 switch. I’ve read a load of other threads which don’t seem to help. Port 80 is open, but redirected, and according to another thread that is enough.
If I manually run certbot-auto renew
and in another terminal watch the contents of docroot, I can see the correct directories and files get created (and then removed). If I manually create those exact dirs/files (with mkdir
and touch
), I can access them via https or http (which just redirects to https). I’ve checked my DNS, everything looks fine AFAICT (and hasn’t changed in years).
Any help appreciated, thank you.
