Certbot and ports confusion
Well, securely yes.
But if you move from port 80 then the renewals via --webroot will fail.
For that scenario you can turn to --standalone as certbot will then be able to stand there (on port 80) all alone whenever it actually needs to renew your certs.
If I want to change my domain name, should I repeat the process?
I will keep an eye on the log files to check renewals etc. , where can i find them pls?
certbot logs will normally go to the /etc/letsencrypt/letsencrypt.log file.
If you change your domain, you will need to create another certonly cert.
Then point your node.js to those new cert files.
Then delete the old/unused cert.
Use: certbot delete --cert-name {whatever the old cert name is}
You can find the names (and lots more) of your cert with:
certbot certificates
[try that one now]
Thats great - I can see the details. Its has 89 days to expire.
Is there a status command for certbot also ?
What are you looking for?
Just curious, I thought there may be some sort of status page to let user know Certbot settings (i.e. mode)
I think in my situation, I.e. using this server for API (and use port 8080/8089), --standalone would be more suited given the amount of work for --webroot.
Not that I plan to, but is it simple enough to switch from --webroot to --standalone mode?
Hindsight is 20/20!
A lot simpler than the other way around - that's for sure!
--standalone takes care of everything - you only need to get off port 80 and let it do its' thing.
Thanks for your help, really appreciated your support and getting me off the ground :clap:
My pleasure :slight_smile:
(again)
Cheers from Miami :beers:
Do let us know if you run into any trouble with the switch from --webroot to --standalone
[I think you are well versed in this now and will be all right - but, if not, we are always here to help]
