This domain has been running Glassfish on http, I want to change to https.
algstoch.eu
/usr/local/bin/certbot-auto certonly --standalone
/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py:163: CryptographyDeprecationWarning: OpenSSL version 1.0.1 is no longer supported by the OpenSSL project, please upgrade. The next version of cryptography will drop support for it.
utils.CryptographyDeprecationWarning
Enter email address (used for urgent renewal and security notices)
(Enter ‘c’ to cancel): <my e-mail>@gmail.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/©ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): algstoch.eu
http-01 challenge for algstoch.eu
Waiting for verification…
Challenge failed for domain algstoch.eu
Domain: algstoch.eu
Type: connection
Detail: Fetching
http://algstoch.eu/.well-known/acme-challenge/iZxjRzObjFebOog2JrRFpZuvYiy98boEKLp6cjU2Eck:
Connection refusedTo fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Your account credentials have been saved in your Certbot
Glassfish 4.1, I stopped it temporarily in order to run certbot
Raspbian 8, based Debian
asadmin
or certbot-auto --version
if you’re using Certbot):
1.4.0
# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT tcp – anywhere anywhere tcp dpt:http
ACCEPT tcp – anywhere anywhere tcp dpt:http-alt
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
# ip6tables -L
