Cert renewal works for deter-mi.net but not for git.deter-mi.net
deter-mi.net
certbot renew --webroot-path /var/www/html/wordpress --dry-run
Processing /etc/letsencrypt/renewal/deter-mi.net.conf
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/deter-mi.net/fullchain.pem
Processing /etc/letsencrypt/renewal/git.deter-mi.net.conf
http-01 challenge for git.deter-mi.net
Using the webroot path /var/www/html/wordpress for all unmatched domains.
Attempting to renew cert (git.deter-mi.net) from /etc/letsencrypt/renewal/git.deter-mi.net.conf produced an unexpected error: Failed authorization procedure. git.deter-mi.net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: 89.82.241.180: Fetching http://git.deter-mi.net/.well-known/acme-challenge/pU2WiYXW2UctQ5QIyf3rF1iBvipkEx0bKYDqQVJqzr0: Timeout during connect (likely firewall problem). Skipping.
Processing /etc/letsencrypt/renewal/www.git.deter-mi.net.conf
http-01 challenge for www.git.deter-mi.net
Attempting to renew cert (www.git.deter-mi.net) from /etc/letsencrypt/renewal/www.git.deter-mi.net.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6.. Skipping.
The following certs could not be renewed:
/etc/letsencrypt/live/determinets.com/fullchain.pem (failure)
/etc/letsencrypt/live/git.deter-mi.net/fullchain.pem (failure)
/etc/letsencrypt/live/www.determinets.com/fullchain.pem (failure)
/etc/letsencrypt/live/www.git.deter-mi.net/fullchain.pem (failure)
The following certs were successfully renewed:
/etc/letsencrypt/live/deter-mi.net/fullchain.pem (success)
2 renew failure(s), 0 parse failure(s)
    Domain: git.deter-mi.net
    Type: connection
    Detail: 89.82.241.180: Fetching
apache
debian
myself
I can login to a root shell on my machine
The version of my client is 0.31.0
Hi @tlloancy, and welcome to the LE community forum :slight_smile:
The failure is via IPv4.
But the name resolves to both IPv6 and IPv4:
Addresses: 2001:861:51c6:48f0:2ef0:5dff:fe9f:d418
           89.82.241.180
That means LE tried IPv6 [preferred] and that failed, then tried IPv4 and that also failed.
If it worked deter-mi.net, then perhaps that site works via IPv6.
OR it worked the last time checked but would also fail if checked today.
In any case, HTTP access is currently broken/blocked for both IPv6 and IPv4:
curl -Ii4 git.deter-mi.net
curl -Ii6 git.deter-mi.net
Also, this really needs an upgrade:
deter-mi.net and git.deter-mi.net both have the same ipv6 ip. I don't understand
That makes two of us.
I also don't understand.
They use the same IPv6 and IPv4 addresses.
You say one works and the other doesn't work.
Today, for me, none of them work:
curl -Ii4 deter-mi.net
curl -Ii6 deter-mi.net
how is deter-mi.net renewd then ?
It was last renewed on: 2023-09-19
I can only assume it worked then, but would fail to renew today.
I don't see how it could renew today using HTTP-01 authentication.
the command up there show it would renew
Where?
I don't see anything showing that a renewal would succeed.
That needs fixing.
When using --dry-run you are using the staging environment.
Although similar, production and staging are not exactly the same [IPs].
Even so, we see the staging system also has trouble reaching the site via HTTP:
The successful renewal could be due to caching.
It might have recently succeeded and isn't actually being tested [via HTTP] today.
Ok lets say i block the port 80 and keep only 443.
Shouldnt it be able to renew anyway ?
No, the renewals require port 80.
[not using the default authentication (HTTP-01)]
port 80 is now open and still
Attempting to renew cert (git.deter-mi.net) from /etc/letsencrypt/renewal/git.deter-mi.net.conf produced an unexpected error: Failed authorization procedure. git.deter-mi.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: 89.82.241.180: Invalid response from https://git.deter-mi.net/.well-known/acme-challenge/nQfI6HGWx_v2E4jpYWD6Y5B_twQ9GqEcfntXWpq59WY: 404. Skipping.
Not from my point on the Internet:
curl -Ii6 http://git.deter-mi.net/.well-known/acme-challenge/Test_File-1234
curl -Ii4 http://git.deter-mi.net/.well-known/acme-challenge/Test_File-1234
i just reopened it
You shouldn't have to open it.
It [HTTP] should always be open.
i can let it open the point is i still have the error while it's open
Then there is more to "open".
It is now open to me:
Date: Tue, 03 Oct 2023 18:14:44 GMT
Server: Apache/2.4.38 (Debian)
Location: https://git.deter-mi.net/.well-known/acme-challenge/Test_File-1234
Date: Tue, 03 Oct 2023 18:14:50 GMT
And Let's Debug can also get through:
Let's Debug (letsdebug.net)
