I don’t see the command
What do you mean? You have to type in that command at your shell prompt.
What command? Re-enter pls
certbot certificates
Found the following certs:
Certificate Name: unifi.tekinfo.ca
Domains: unifi.tekinfo.ca
Expiry Date: 2019-12-10 13:12:15+00:00 (VALID: 62 days)
Certificate Path: /etc/letsencrypt/live/unifi.tekinfo.ca/fullchain.pem
Private Key Path: /etc/letsencrypt/live/unifi.tekinfo.ca/privkey.pem
Thanks, could you now try running this command from the tutorial?
sudo /usr/local/bin/unifi_ssl_import.sh
(if this works, then there’s still a question about why it wasn’t running automatically; if it doesn’t work, then we might be able to see why it fails)
Thanks, everything is back fine
Thanks for your times
It might be good to understand why this didn’t run automatically. The tutorial indicates that you can create a cron job which will run the command automatically, so if you followed the whole tutorial, this should have happened on its own without needing to do it by hand.
