My domain is: planettel.com.sg
I ran this command:certbot-auto
It produced this output: Does not detect the domain to issue cert
My web server is (include version):apache
The operating system my web server runs on is (include version):Debian
I can login to a root shell on my machine (yes or no, or I donāt know):yes
Iām using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youāre using Certbot):1.2.0
I am able to get certs for top level domains. Does letsencrypt support domain name like .com.sg ?
Are you getting an error message from Letās Encrypt?
Certbot detects hostnames based on your Apache ServerName and ServerAlias settings (or the equivalent for Nginx). Do you have a virtual host configured for this domain? Or you can also get certificates for names that Certbot did not automatically detect.
I have configured several top level domains using virtual hosts and when I run certbot-auto it will automatically detect all the domains with virtual hosts so I can select the domain to get letsencrypt cert. However, for this domain when I run certbot-auto it does not list it in the domains to get cert. Strange! I do have the virtual host configured for this domain āplanettel.com.sgā
Following is my entry in the virtual host conf file in āsites-availableā:
Hi, Thanks for the prompt responses and helping me to debug.
I realised that i made a typo error while enabling the virtual host.
I corrected that error and the problem has been resolved.
This issue may be closed.
Regards,
