Cerificate renewal faild with During secondary validation:
our domain is apps.factnet.co.in:
sudo certbot certonly --nginx then I got the following error message
Domain: apps.factnet.co.in
Detail: During secondary validation: 61.1.183.84: Invalid response from http://apps.factnet.co.in/.well-known/acme-challenge/vTs41fA2LQVOOK4A1VuAurjdjUYznsxhg55W4KgkiDE: 400
Ubuntu 20.04 with nginx server
I can login to a root shell on my machine:yes
The version of my client is certbot 2.10.0
I run all the options from lets debug then shows everything is ok
that means primary vantage point saw right result but some of others seen wrong message : do you happen to block AWS or some nations?
At present not blocked to any nations
for some reason your website thinks port 80 is https port hand prints error 400
Yes. I temporally disabled the https. now am able to renew the certificate. Thankyou @orangepizza
