My domain is:histoire.espacedesgaulois.org
apache status is on
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor pre>
Active: active (running) since Fri 2025-11-07 14:45:33 CET; 19min ago
Docs: Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Main PID: 13741 (apache2)
Tasks: 55 (limit: 4455)
Memory: 7.0M
CGroup: /system.slice/apache2.service
├─13741 /usr/sbin/apache2 -k start
├─15594 /usr/sbin/apache2 -k start
└─15595 /usr/sbin/apache2 -k start
nov. 07 14:45:33 puyuelo-K72Jr systemd[1]: Starting The Apache HTTP Server...
nov. 07 14:45:33 puyuelo-K72Jr apachectl[13740]: AH00558: apache2: Could not >
nov. 07 14:45:33 puyuelo-K72Jr systemd[1]: Started The Apache HTTP Server.
It produced this output:/usr/bin/certbot:6: DeprecationWarning: pkg_resources is deprecated as an API. See Package Discovery and Resource Access using pkg_resources - setuptools 80.9.0 documentation
from pkg_resources import load_entry_point
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): jpuy888@laposte.net
https://letsencrypt.org/documents/LE-SA-v1.5-February-24-2025.pdf. You must
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let's Encrypt project and the non-profit
organization that develops Certbot? We'd like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: N
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel): histoire.espacedesgaulois.org www.histoire.espacedesgaulois.org
http-01 challenge for histoire.espacedesgaulois.org
http-01 challenge for www.histoire.espacedesgaulois.org
Enabled Apache rewrite module
Challenge failed for domain www.histoire.espacedesgaulois.org
Challenge failed for domain histoire.espacedesgaulois.org
Domain: histoire.espacedesgaulois.org
Type: connection
Detail: 92.184.100.31: Fetching
http://histoire.espacedesgaulois.org/.well-known/acme-challenge/iq9btzpnkU_x4HG1V4D_WB9r_vmDYNBqSmJzUG1GsRo:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Domain: www.histoire.espacedesgaulois.org
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for
www.histoire.espacedesgaulois.org - check that a DNS record exists
for this domain; DNS problem: NXDOMAIN looking up AAAA for
for this domain -
Your account credentials have been saved in your Certbot
My web server is (include version): apache
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
