I received an email for renewal. Went to run the cerbot renew command but the cerbot command is not on the machine (although it was when I did the last renewal). All I can think of is that some update screwed with cerbot.
I’m running jessie on a RPi-3 with apache web server.
I did run a find command
find / -name *cerbot* -print to be sure I really do not have the command.
Then I found info that suggested running:
sudo apt-get install python-cerbot-apache -t jessie-backports
Reading package lists… Done
E: The value ‘jessie-backports’ is invalid for APT::Default-Release as such a release is not available in the sources
So now I’m a lost soul wanting to not screw up the machine worse than it is.
Suggestions?
Thanks
