Centos CWP admin not enabled
I am trying to apply lets encrypt to my admin webpanel
using my domain name russromei.xyz for both the admin panel and a website, it works fine on the website and website user panel, but not the (root) admin panel.
I login to both using the domain name but different ports
My domain is: russromei.xyz
My web server is (include version): centos 7
The operating system my web server runs on is (include version): centos 7
I'm using a control panel to manage my site: CWP - Centos Web Panel Pro
Hi @russ1, and welcome to the LE community forum :slight_smile:
What error is shown when it fails to connect?
Which port is the failure?
It looks like you are using the standard port 2031 to connect to your Centos Web Panel. It is currently sending out the self-signed cert:
subject=C = HR, ST = Zagreb, O = CentOS Web Panel, L = HR, CN = racknerd-51478c127.0.0.1, OU = CentOS Web Panel, emailAddress = info@studio4host.com
I believe you need to ensure your CWP hostname matches your web server hostname. But, I am not expert with CWP. You might want to ask at the CWP forum
Yes, they match though I don't know who info@studio4host.com is
no error, just no SSL
2031
