Why are they serving a redirect to http://mclnfriends.com? Why is your server not reachable?
Not sure. Can you share with me how you came up with that so I can get with namecheap and get it resolved. When I try to go to www.mlcnfriends.com I get a redirect to mlcnfriends.com
mlcnfriends.com is the correct URL.
$ dig www.mlcnfriends.com
; <<>> DiG 9.9.5-9+deb8u4-Debian <<>> www.mlcnfriends.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16649
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 3
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;www.mlcnfriends.com. IN A
;; ANSWER SECTION:
www.mlcnfriends.com. 1271 IN A 67.209.241.26
www.mlcnfriends.com. 1271 IN A 192.64.119.108
;; AUTHORITY SECTION:
mlcnfriends.com. 1253 IN NS dns1.registrar-servers.com.
mlcnfriends.com. 1253 IN NS dns2.registrar-servers.com.
;; ADDITIONAL SECTION:
dns1.registrar-servers.com. 163745 IN A 216.87.155.33
dns2.registrar-servers.com. 163745 IN A 216.87.152.33
;; Query time: 8 msec
Then
$ printf 'GET / HTTP/1.0\r\nHost: www.mlcnfriends.com\r\n\r\n' | nc 192.64.119.108 80
HTTP/1.1 302 Moved Temporarily
Server: nginx
Date: Sat, 14 Jan 2017 17:06:38 GMT
Content-Type: text/html
Connection: close
Content-Length: 154
<html>
<head><title>302 Found</title></head>
<body bgcolor="white">
<center><h1>302 Found</h1></center>
<hr><center>nginx</center>
</body>
</html>
(note the typo in the Location header) and
$ printf 'GET / HTTP/1.0\r\nHost: www.mlcnfriends.com\r\n\r\n' | nc 67.209.241.26 80
(UNKNOWN) [67.209.241.26] 80 (http) : Connection timed out
These are the root causes.
67.209.241.26
is reachable from my end. But indeed, 192.64.119.108
is the culprit for the typo in the redirect.
Your nginx
is searching for the file in /usr/local/etc/nginx/html
according to the error log you just pasted. It doesn't think that up by its own Or you typed the log entry wrongly?
This serverâs firewall is configured weirdly it seems. Or its routing is wrong.
# traceroute -I -f 6 67.209.241.26
traceroute to 67.209.241.26 (67.209.241.26), 30 hops max, 60 byte packets
6 80.157.130.154 (80.157.130.154) 117.834 ms 117.781 ms 117.772 ms
7 cer-edge-17.inet.qwest.net (67.14.8.86) 131.284 ms 131.274 ms 131.826 ms
8 63.145.140.122 (63.145.140.122) 143.641 ms 143.990 ms 143.979 ms
9 a67-209-250-129.cust.mi.winntel.net (67.209.250.129) 139.929 ms 140.131 ms 140.297 ms
10 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 140.855 ms 140.846 ms 140.846 ms
11 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 164.602 ms 155.453 ms 158.004 ms
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 *^C
A traceroute shouldnât look like that.
I bet anything it was from the automatic park on www that they put in place when I registered the domain. I'll get with them and see if I can get it resolved. Thanks so much for your help with this.
Again, I don't know how since it's not referenced on any of the config files. The config files are posted and you can see what's in them.
This server's firewall is configured weirdly it seems. Or its routing is wrong.
# traceroute -I -f 6 67.209.241.26 traceroute to 67.209.241.26 (67.209.241.26), 30 hops max, 60 byte packets 6 80.157.130.154 (80.157.130.154) 117.834 ms 117.781 ms 117.772 ms 7 cer-edge-17.inet.qwest.net (67.14.8.86) 131.284 ms 131.274 ms 131.826 ms 8 63.145.140.122 (63.145.140.122) 143.641 ms 143.990 ms 143.979 ms 9 a67-209-250-129.cust.mi.winntel.net (67.209.250.129) 139.929 ms 140.131 ms 140.297 ms 10 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 140.855 ms 140.846 ms 140.846 ms 11 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 164.602 ms 155.453 ms 158.004 ms 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 *^C
A traceroute shouldn't look like that.
What part looks odd?
The destination host should be the last one that answers. It shouldnât answer twice and there shouldnât be hops beyond it.
Depends. Many routers/firewalls block traceroutes (mostly ICMP), but don't block plain HTTP(S) packages through port 80/443 et cetera.
The traceroute looks the same from my end and the webserver is reachable.[quote="Jailer, post:26, topic:25672"]
[/quote]
Did you copy/paste the error log or type it?
The traceroute still wouldn't look like that.
Onus probandi
There, satisfied?:
osiris@desktop ~ $ sudo traceroute -T -p 80 67.209.241.26
1 speedtouch (192.168.1.254) 0.519 ms 0.662 ms 0.804 ms
2 lo0.dr13.d12.xs4all.net (194.109.5.212) 8.683 ms 8.891 ms 9.279 ms
3 0.ae23.xr4.1d12.xs4all.net (194.109.7.17) 9.276 ms 0.ae23.xr3.3d12.xs4all.net (194.109.7.53) 9.271 ms 0.ae23.xr4.1d12.xs4all.net (194.109.7.17) 10.454 ms
4 0.ae5.xr1.sara.xs4all.net (194.109.5.2) 10.450 ms 10.445 ms 0.ae4.xr1.sara.xs4all.net (194.109.5.6) 10.774 ms
5 30gigabitethernet1-3.core1.ams1.he.net (80.249.209.150) 35.763 ms 35.775 ms 36.061 ms
6 100ge9-1.core1.lon2.he.net (72.52.92.213) 20.523 ms 30.160 ms 31.424 ms
7 100ge1-1.core1.nyc4.he.net (72.52.92.166) 97.662 ms 93.584 ms 93.532 ms
8 100ge5-1.core1.chi1.he.net (184.105.223.161) 100.448 ms 101.258 ms 104.555 ms
9 216.66.76.146 (216.66.76.146) 115.074 ms 115.283 ms 117.003 ms
10 a67-209-250-129.cust.mi.winntel.net (67.209.250.129) 111.547 ms 111.697 ms 114.011 ms
11 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 116.251 ms 116.548 ms 115.470 ms
12 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 128.396 ms 130.206 ms 130.535 ms
13 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 148.066 ms 144.593 ms 147.679 ms
14 67-209-241-26.dhcp.portland.mi.freedomnet.com (67.209.241.26) 144.304 ms 134.016 ms 137.344 ms
osiris@desktop ~ $
I agree, it does look strange, but it doesn't have anything to do with the non-reachability on your end, as demostrated above.
Copied and pasted a snippet. The entire error from the last dry run I tried is below
2017/01/14 10:28:01 [error] 36698#102176: *2 open() "/usr/local/etc/nginx/html/.well-known/acme-challenge/ULP8x7iZI-vStfFCooMZGGqOjmAniOz0P9cyCLx5a_s" failed (2: No such file or directory), client: 66.133.109.36, server: www.mlcnfriends.com, request: "GET /.well-known/acme-challenge/ULP8x7iZI-vStfFCooMZGGqOjmAniOz0P9cyCLx5a_s HTTP/1.1", host: "www.mlcnfriends.com", referrer: "http://www.mlcnfriends.com/.well-known/acme-challenge/ULP8x7iZI-vStfFCooMZGGqOjmAniOz0P9cyCLx5a_s"
The traceroute would stop somewhere in front or at the host. Certainly the host wouldnât answer twice and then still have hops beyond itself.
Is your webroot /usr/local/www/nginx
a symlink perhaps? I.e., try ls -ld /usr/local/www/nginx
Because that would explain the log entry. (But not why it isn't working.)
@Jailer, can you show netstat -rn
output on the host? Are these jails? Can you show the packet filter config?
Sure it does, or is your IP address the same as mine? There is definitely something wrong on the routing level (as also evidenced by the very first post in this entire thread).
The error in the first post is because of the typo in the redirect at namecheap.
Futher, my traceroute through TCP port 80 ends perfectly without timeouts (although it does give 4 hops of the last hop, indeed, but it works) and my telnet to port 80 works too.. So I'm quite convinced this is not a global routing or firewall issue.
It works for your connection. That doesnât mean it works for everyone.
In post 3 @Jailer got a 404 file not found error from Letâs Encrypt⌠Which means there was a successful connection on OSI layer 4.
Is your webroot
a symlink perhaps? I.e., tryls -ld /usr/local/www/nginx
Negative, it's a directory.
drwxr-xr-x 3 root wheel 4 Jan 7 13:05 /usr/local/www/nginx
netstat -rn
Yes these hosts are in jails. Requested output below.
Routing tables
Internet:
Destination Gateway Flags Netif Expire
default 192.168.0.1 UGS epair5b
127.0.0.1 link#1 UH lo0
192.168.0.0/24 link#2 U epair5b
192.168.0.225 link#2 UHS lo0
Internet6:
::/96 ::1 UGRS lo0
::1 link#1 UH lo0
::ffff:0.0.0.0/96 ::1 UGRS lo0
fe80::/10 ::1 UGRS lo0
fe80::%lo0/64 link#1 U lo0
fe80::1%lo0 link#1 UHS lo0
ff01::%lo0/32 ::1 U lo0
ff02::/16 ::1 UGRS lo0
ff02::%lo0/32 ::1 U lo0
Maybe the client chose the other IP address this time. I have a host in .sk from where it works. I also have a host in .uk from where it doesnât work.
Your methodology is flawed.
