Can't renew with certbot or Crypt::LE, Timeout during secondary validation (403 resolved)
I don't know if that is fruitful. The Let's Encrypt Server gives up once it knows for sure it can't satisfy the cert request. That is, once it learns the primary times out the challenge fails. Or, if more than 1 secondary times out the challenge fails. Or, if it flat out gets wrong data responses rather than timeouts it fails.
So, there may be an element of timing as to how many you see depending on the underlying traffic flows and timeout detections. Emphasis on "may" as I have not studied the LE Boulder code in detail but that is the concept of what happens.
The last one with only 3 Apache log entries had a subset of the one with 4 log entries. I didn't look at the earlier as missing the Primary center is a major failure.
It depends which four. The Primary center must pass - always.
I see. Does that mean that's the one (or one of the ones) that's consistently failing? That's interesting, though I'm not sure what the implications are.
It does. I looked at the 4 IP and they were all from AWS data centers which are all Secondary centers. An IP for the Primary center is missing.
The fact we see 4 requests and still fails also means that.
I don't understand...
Previous log entries [failures]:
Your recent requests [success]:
I can't reconcile those differences.
Maybe it is a PID (%P) rather than the size of response bytes (%B) ? :slight_smile:
This thread has some of the most peculiar combination of oddities.
I don't think the log value is an accurate response bytes. Wouldn't the failure message say "faulty data" rather than timeout if it were?
Then we would need to see the log definition [to be sure].
But I do follow the logic of it is not what we think it is/should be.
I suspect something default, like:
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
That's likely. And, %O includes headers so maybe there are some unneeded headers
I've never messed around with changing the log format, so it should be whatever the default is in Devuan. Hang on, lemme look up where it's configured...
Hmm, /etc/apache2/apache2.conf has this:
LogFormat "%v:%p %h %l %u %t "%r" %>s %O "%{Referer}i" "%{User-Agent}i"" vhost_combined
LogFormat "%h %l %u %t "%r" %>s %O "%{Referer}i" "%{User-Agent}i"" combined
LogFormat "%h %l %u %t "%r" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
And then sites-enabled/000-default.conf has this:
So that suggests this:
So I think the field we're looking at is the %O yes? I think. Unless I am missing something. Again, I have a lot more experience looking at the error log than the access log, and no experience at all with configuring the log formats to anything other than the default. And it's been a rather long time since I've hosted Apache on anything other than Debian (pre-Poettering) and now Devuan, so my notion of the default, is whatever the Debian package maintainer thinks the default should be.
https://httpd.apache.org/docs/2.4/mod/mod_log_config.html#formats
Yes.
I don't understand why the logs shows anything other than 87.
We need to capture one of those replies.
Wouldn't the reply look like below? I didn't count every byte but it's somewhere in the 300s including headers. The %O says it includes the header bytes.
curl -i http://cgi.galion.lib.oh.us/.well-known/acme-challenge/y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A
HTTP/1.1 200 OK
Date: Thu, 25 Apr 2024 13:20:42 GMT
Server: Apache/2.4.59 (Debian)
Last-Modified: Wed, 24 Apr 2024 17:58:02 GMT
ETag: "57-616db69675ce0"
Accept-Ranges: bytes
Content-Length: 87
y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A.AT5JajgpWjv1ULtDGDL25oQO0YEHg-QklIW6-jtJrVA
For curl -I requests, yes.
But why would LE make such a request?
The lower case i does a GET and has curl show the headers and data.
Omitting that lower case i would still do a GET but only show the response data.
Their Apache would be sending headers and data for any request. And thus its length would be reflected in its own log.
I suppose
you may be right...
[I may be crazy]
I'm sure you have a spare Apache laying around. Setup a log format that includes %O and %B. Make sure your Apache sends some headers with every response. Then send a curl with and without a lower case i and see if those log values change. They shouldn't. The O entry will include the length of the headers and the B just the data.
That would take time... [away from my :beers:]
And it wouldn't explain why sometimes it was 308 and other times 345.
But it is a red herring none-the-less.
Yes, a diversion. The 345 length log entries were from their wget tests. The response headers were longer for those as they included some "keep-alive" info. wget probably sets different request headers compared to curl (and LE) resulting in slightly different response headers.
Why the LE Primary data center cannot reach their server is still a mystery.
Showing the entire reply including headers is what wget -S does:
jonadab@hippo:~$ wget -S http://cgi.galion.lib.oh.us/.well-known/acme-challenge/y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A
--2024-04-25 11:08:23-- http://cgi.galion.lib.oh.us/.well-known/acme-challenge/y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A
Resolving cgi.galion.lib.oh.us (cgi.galion.lib.oh.us)... 66.213.116.5
Connecting to cgi.galion.lib.oh.us (cgi.galion.lib.oh.us)|66.213.116.5|:80... connected.
HTTP request sent, awaiting response...
HTTP/1.1 200 OK
Date: Thu, 25 Apr 2024 15:08:23 GMT
Content-Length: 87
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Length: 87
Saving to: ‘y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A.2’
y13yBugLjpX9LrHjJA7AwI3RHxPgi 100%[=================================================>] 87 --.-KB/s in 0s
2024-04-25 11:08:23 (10.4 MB/s) - ‘y13yBugLjpX9LrHjJA7AwI3RHxPgiUOhMeNpgAxUw0A.2’ saved [87/87]
You have new mail in /var/mail/jonadab
jonadab@hippo:~$
So yeah, the headers are somewhere in the 300-byte range, but it would vary depending on stuff like what headers the client sent, because the server responds to those. That's all a normal part of http, as I understand it. In principle the headers can even have cookies in them, although in this case they wouldn't, because the files being served are static (and I haven't set up any site-wide cookie apparatus).
For the sake of completeness:
Wed_2024-May-01_15:00
jonadab@ostrich:~$ telnet www.galionlibrary.org 80
Trying 66.213.116.5...
Connected to www.galionlibrary.org.
Escape character is '^]'.
GET http://www.galionlibrary.org/.well-known/acme-challenge/06Zqq3xKoJl0b5n-sWip_F-uHiGfxjYf_Dv_E0P3q0s HTTP/1.1
Host: www.galionlibrary.org
HTTP/1.1 200 OK
Date: Wed, 01 May 2024 19:00:45 GMT
Last-Modified: Wed, 24 Apr 2024 19:31:46 GMT
ETag: "57-616dcb8a557d7"
Content-Length: 87
06Zqq3xKoJl0b5n-sWip_F-uHiGfxjYf_Dv_E0P3q0s.AT5JajgpWjv1ULtDGDL25oQO0YEHg-QklIW6-jtJrVAConnection closed by foreign host.
Wed_2024-May-01_15:01
jonadab@ostrich:~$
But yes, this is a rabbit trail. The size of the http headers is unlikely to be related to the problem.
