Can't get a SSL Certificate using NGINX and Lets Encrypt
My domain is: lapsmith.duckdns.org
I ran this command: Didn't run a command, tried using NGINX
My web server is (include version): Not sure what this is, I am trying to get the certificate to use with Home Assistant (Tesla Integration)
The operating system my web server runs on is (include version): HAOS
My hosting provider, if applicable, is: DuckDNS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Using Home Assistant UI
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I don't know
Unless it is obvious from the error message below, I'm not even sure if I am entering the correct information:
Here is the error message:
CommandError: Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Encountered exception during recovery: certbot.errors.PluginError: The TXT value for domain "lapsmith.duckdns.org" could not be deleted.
Request status code: 200
Request response text: KO
The TXT update "KO" for domain "jiUE_RDl679UCAhmIu7csySuZjgnhHYEdJW4LlmATq4" could not be set.
Request status code: lapsmith.duckdns.org
Request response text: 200
Based on a post by someone who had a similar problem, I ran my domain through dnssec-debugger and there may be a problem with DNSSEC signatures, whatever that means. Google says I may have to wait 48 hours after creating the domain for propogation. Could that be all it is?
The errors it found are:
No DS records found for duckdns.org in the org zone
No DNSKEY records found
and multiple instances of: No RRSIGs found
Thanks!
duckdns.org is unsigned and not having DS, DNSKEY or RRSIG records is expected. have you made sure that the credential file content is correct i.e. have you replaced your-duckdns-token with your duckdns API token?
Ah, makes sense! I had tried replacing all the text in that box with my API token, not realizing I had to replace just the "your-duckdns-token". Now it worked, thanks so much!!
