If you are continuing to have issues with networking, ports and port forwarding while using the HTTP challenge, consider giving certbot-dns-duckdns a go, which may simplify your task.
Is the DDNS IP up-to-date?
Check:
curl -4 ifconfig.io
Nothing is listening at the moment [on 80 or 443]:
curl http://studiodomotico.duckdns.org
curl https://studiodomotico.duckdns.org
curl: (7) Failed to connect to studiodomotico.duckdns.org port 443: No route to host
You save me. It works, thank a lot
