I found the problem, I just don't know how to fix it...
I can only have one port open at a time, and I don't know why. I removed everything from the table and added port 80 first and then port 433. Now port 80 is open and port 433 is closed...
Looks good from my IPv4 location as well
$ nmap -Pn varelasnkrs.com
Starting Nmap 7.80 ( https://nmap.org ) at 2023-03-04 23:30 UTC
Nmap scan report for varelasnkrs.com (129.151.227.103)
Host is up (0.17s latency).
Not shown: 997 filtered ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
Nmap done: 1 IP address (1 host up) scanned in 12.96 seconds
Here is another problem:
These 3 links work:
But this one doesn't:
http://www.varelasnkrs.com
And I also would like to make the www. version the default address (that everything gets redirected to) and not the one without www, but I don't know what to change to make that happen...
Here is an online tool to assist with checking redirects https://www.redirect-checker.org/
$ curl -Ii http://www.varelasnkrs.com/
HTTP/1.1 404 Not Found
Server: nginx/1.18.0 (Ubuntu)
Date: Sat, 04 Mar 2023 23:38:23 GMT
Content-Type: text/html
Content-Length: 162
$ curl -Ii https://varelasnkrs.com/
HTTP/1.1 200 OK
Date: Sat, 04 Mar 2023 23:37:16 GMT
Link: <https://varelasnkrs.com/wp-json/>; rel="https://api.w.org/"
Link: <https://varelasnkrs.com/wp-json/wp/v2/pages/1986>; rel="alternate"; type="application/json"
Link: <https://varelasnkrs.com/>; rel=shortlink
$ curl -k -Ii https://www.varelasnkrs.com/
Date: Sat, 04 Mar 2023 23:37:40 GMT
X-Redirect-By: WordPress
$ curl -Ii http://varelasnkrs.com/
Date: Sat, 04 Mar 2023 23:38:00 GMT
Content-Length: 178
I will have to go back and RTFM to learn what is meant by "filtered
" [if NOT "closed
Filtered is when no packages get returned by the server, whereas closed means the server actively closed the connection when receiving an incoming connection using an ICMP reply. OP used such a firewall rule earlier shown in this thread (the one with -j REJECT
I know this is unrelated but can you help me? This website is migrated using all-in-one wp migration plugin from another host to a nginx server running in Oracle Cloud. After the migration the permalinks broke and I can't find a way to fix them. I can only access the homepage. I already tried changing the structure to another one and back to the old one and it didn't work. Making another .htaccess file doesn't work either (this wp never created one).
I do not actually know enough to be able to help.
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist.
I'm afraid that's quite out of the scope of this Community.
Please see Post #26 in this thread:
