Can we run sudo certbot --apache and setup auto renew while having a running HTTPS configured via Certbot using DNS challenge?
I previously used the DNS challenge to setup my first SSL with Certbot. But now that I want to use the HTTP one to take advantage of the auto-renew possibilities, the command sudo certbot --apache --debug-challenge seems to not work. The acme-challenge folder files are accessible. Here is an example, https://salvomag.com/.well-known/acme-challenge/G28T9ScQU1szGFOZWGRyZhl5jIoWziBarr8MxreQDok
My domain is: salvomag.com
I ran this command: sudo certbot --apache --debug-challenge
1: salvomag.com
2: www.salvomag.com
blank to select all options shown (Enter ‘c’ to cancel): 1 2
http-01 challenge for salvomag.com
http-01 challenge for www.salvomag.com
Waiting for verification…
Challenges loaded. Press continue to submit to CA. Pass “-v” for more info about
challenges.
Press Enter to Continue
Failed authorization procedure. salvomag.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://salvomag.com/.well-known/acme-challenge/i5A8wcpKIh-X09bvFNvpLEty0WousJdXI8fWhy5f_Cs [167.99.158.70]: “<!doctype html>\n<html class=“no-js” lang=“en”>\n <head>\n <meta charset=“utf-8” />\n <meta name=“viewport” content”, www.salvomag.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://www.salvomag.com/.well-known/acme-challenge/cNlc3bzilIDKL87xosBf_GY545IND3aGcxuK0BQt3nA [167.99.158.70]: “<!doctype html>\n<html class=“no-js” lang=“en”>\n <head>\n <meta charset=“utf-8” />\n <meta name=“viewport” content”
    • The following errors were reported by the server:*
Domain: salvomag.com
Detail: Invalid response from
[167.99.158.70]: "<!doctype html>\n<html class=“no-js”
<meta name=“viewport” content"
Domain: www.salvomag.com
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 16.04.6 LTS
My hosting provider, if applicable, is: Digital Ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
Hi @oscarouedraogo
first: It isn't relevant which challenge method you have used earlier. That doesn't affect your current command.
Checked your domain there is a problem (via https://check-your-website.server-daten.de/?q=salvomag.com ):
• http://salvomag.com/
167.99.158.70 302 https://salvomag.com/ 0.220 A
• http://www.salvomag.com/
167.99.158.70 302 https://www.salvomag.com/ 0.217 A
• https://salvomag.com/
167.99.158.70 200 7.137 I
• https://www.salvomag.com/
167.99.158.70 200 6.887 I
• http://salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
167.99.158.70 302 https://salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.213 A
Visible Content: Found The document has moved here . Apache/2.4.18 (Ubuntu) Server at salvomag.com Port 80
• http://www.salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
167.99.158.70 302 https://www.salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.213 A
Visible Content: Found The document has moved here . Apache/2.4.18 (Ubuntu) Server at www.salvomag.com Port 80
• https://salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 200 6.226
Visible Content: Salvo Login 404 This page either moved or does not exist. Try browsing our current issue or search our archives . Are you looking to renew your subscription? Click here . Back to Home Welcome, friend. Sign-in to read every article [or subscribe .] Guest Login Welcome back. Your username and password, please? Subscriber Login Salvo A MAGAZINE OF SOCIETY, SEX, & SCIENCE Subscribe Topics Departments Authors Fake Ads About Salvo Contact Privacy Policy Current Issue Past Issues Subscribe Renew Student Subscription Gift Salvo Donate Facebook Twitter Newsletters Login All material Ⓒ 2019 Salvo is published by The Fellowship of St. James. Designed by Beck & Stone, Inc. Login Topics Departments Authors Fake Ads About Salvo Current Issue Past Issues Gift Salvo Donate Privacy Policy Subscribe Renew Student Subscription Newsletters Facebook Twitter Contact
• https://www.salvomag.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 200 6.237
Port 80 is open and answers, that's good (and required). If you use http-01 validation, Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks that file.
The redirect http -> https is ok, Letsencrypt follows that redirect (and ignores invalid certificates).
But then your server answers with a http status 200 and a lot of content.
So it looks that there is a content management system or something else. Expected is the http status 404 (not found), not the http status 200 / ok.
It may be difficult to change that.
Perhaps it's easier to find your port 80 vHost, there the rewrite rule http -> https, then create an exception, so /.well-known/acme-challenge isn't redirected to https.
Thanks @JuergenAuer. I have excluded the well-known path and it worked. Strange that the well known link that I have specified in my post description was working.
Now when I run sudo certbot renew --dry-run, I get 0 renew failure(s), 1 parse failure(s).
Below is the full output
Processing /etc/letsencrypt/renewal/salvomag.com-0002.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/salvomag.com-0002/fullchain.pem
Processing /etc/letsencrypt/renewal/salvomag.com.conf
  • File “/usr/lib/python3/dist-packages/certbot/renewal.py”, line 64, in _reconstitute*
  • renewal_candidate = storage.RenewableCert(full_path, config)*
  • File “/usr/lib/python3/dist-packages/certbot/storage.py”, line 441, in init*
  • “file reference”.format(self.configfile))*
    certbot.errors.CertStorageError: renewal config file {} is missing a required file reference
    Renewal configuration file /etc/letsencrypt/renewal/salvomag.com.conf is broken. Skipping.
*** DRY RUN: simulating ‘certbot renew’ close to cert expiry*
*** (The test certificates below have not been saved.)*
  • /etc/letsencrypt/live/salvomag.com-0002/fullchain.pem (success)*
*Additionally, the following renewal configurations were invalid: *
  • /etc/letsencrypt/renewal/salvomag.com.conf (parsefail)*
    *** (The test certificates above have not been saved.)*
Wondering if the renewal cronjob will work at the renewal time.
You have created a new certificate:
CN=salvomag.com
	12.03.2019
	10.06.2019
expires in 90 days	salvomag.com, www.salvomag.com - 2 entries
So that works. And now you have two config files:
The first may be your new certificate, the second may be your old.
But you need only one certificate.
So check your config with
certbot certificates
if the 002 has the correct certificate, remove the other certificate with
certbot delete certificate-name
PS: First make a backup.
It all worked out. Thanks @JuergenAuer!
