Can not get SSL to work on LAMP with WordPress site
If you see URLs starting with HTTP, then you need to go ahead and change them to HTTPS!
For some reason the browser will not show http or https. It doesn’t matter if I enter https://www.mydomain.com or http://www.mydomain.com, the browser will always show mydomain.com only.
But when I enter http it will load the page and when I enter https it will not. So the protocol is definitely taking effect.
I read the documentations @JimPas showed and it is the way I should build the server (I used a LAMP package instead, many years ago, without knowing much about anything.) So I will get a new server and rebuild properly and move my sites over.
Thank you for all your helps. Wish me luck.
