Hi Experts,
After trying to get the combo OPNsense, HAProxy and Let’s Encrypt working for a few days it still isn’t working and you all are my last straw…
Before i had ports forwarded to my Synology NAS and on the NAS i did the renewal of my certificate.
Now i changed to a diy build router with OPNsense as the routerOS and want to start managing my certificates through the plugins Let’s Encrypt and HAProxy.
For my shiny new domain example.com (name changed) i tried to get a first certificate which did not work and then i tried to forcefully renew my jekare.nl certificate. Neither one succeeded.
Now i get the feeling i must have messed up something really bad because on jekare.nl i get the warning NET::ERR_CERT_DATE_INVALID although crt.sh reports 4 certificates all valid from 2019-01-19 to 2019-04-19.
I get the feeling there is something wrong with my account key, but don’t know how to fix it. Please help…
Kind regards,
Jack Reitsema.
multiple domains, but this post is about jekare.nl and a brandnew domain example.com (name changed)
I ran the commands using the OPNsense GUI.
First the attempt with example.com on production environment:
[Tue Jan 22 18:06:17 CET 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Tue Jan 22 18:06:17 CET 2019] DOMAIN_PATH='/var/etc/acme-client/home/example.com'
[Tue Jan 22 18:06:17 CET 2019] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Tue Jan 22 18:06:17 CET 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Tue Jan 22 18:06:17 CET 2019] GET
[Tue Jan 22 18:06:17 CET 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Tue Jan 22 18:06:17 CET 2019] timeout=
[Tue Jan 22 18:06:18 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 18:06:18 CET 2019] ret='0'
[Tue Jan 22 18:06:18 CET 2019] ACME_KEY_CHANGE='https://acme-v01.api.letsencrypt.org/acme/key-change'
[Tue Jan 22 18:06:18 CET 2019] ACME_NEW_AUTHZ='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 18:06:18 CET 2019] ACME_NEW_ORDER='https://acme-v01.api.letsencrypt.org/acme/new-cert'
[Tue Jan 22 18:06:18 CET 2019] ACME_NEW_ACCOUNT='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Tue Jan 22 18:06:18 CET 2019] ACME_REVOKE_CERT='https://acme-v01.api.letsencrypt.org/acme/revoke-cert'
[Tue Jan 22 18:06:18 CET 2019] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Tue Jan 22 18:06:18 CET 2019] ACME_NEW_NONCE
[Tue Jan 22 18:06:18 CET 2019] ACME_VERSION
[Tue Jan 22 18:06:18 CET 2019] Le_NextRenewTime
[Tue Jan 22 18:06:19 CET 2019] _on_before_issue
[Tue Jan 22 18:06:19 CET 2019] _chk_main_domain='example.com'
[Tue Jan 22 18:06:19 CET 2019] _chk_alt_domains='www.example.com'
[Tue Jan 22 18:06:19 CET 2019] Le_LocalAddress
[Tue Jan 22 18:06:19 CET 2019] d='example.com'
[Tue Jan 22 18:06:19 CET 2019] Check for domain='example.com'
[Tue Jan 22 18:06:19 CET 2019] _currentRoot='/var/etc/acme-client/challenges'
[Tue Jan 22 18:06:19 CET 2019] d='www.example.com'
[Tue Jan 22 18:06:19 CET 2019] Check for domain='www.example.com'
[Tue Jan 22 18:06:19 CET 2019] Using config home:/var/etc/acme-client/home
[Tue Jan 22 18:06:19 CET 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Tue Jan 22 18:06:19 CET 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Tue Jan 22 18:06:19 CET 2019] RSA key
[Tue Jan 22 18:06:22 CET 2019] Registering account
[Tue Jan 22 18:06:22 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Tue Jan 22 18:06:22 CET 2019] payload='{"resource": "new-reg", "contact": ["mailto: jkr@example.com"], "terms-of-service-agreed": true, "agreement": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf"}'
[Tue Jan 22 18:06:22 CET 2019] GET
[Tue Jan 22 18:06:22 CET 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Tue Jan 22 18:06:22 CET 2019] timeout=
[Tue Jan 22 18:06:22 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 18:06:22 CET 2019] ret='0'
[Tue Jan 22 18:06:23 CET 2019] POST
[Tue Jan 22 18:06:23 CET 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Tue Jan 22 18:06:23 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 18:06:24 CET 2019] _ret='0'
[Tue Jan 22 18:06:24 CET 2019] code='201'
[Tue Jan 22 18:06:24 CET 2019] Registered
[Tue Jan 22 18:06:24 CET 2019] _accUri='https://acme-v01.api.letsencrypt.org/acme/reg/50005563'
[Tue Jan 22 18:06:24 CET 2019] Calc CA_KEY_HASH='vO9uMt5xKBLM2pFzTHL4nTXX1zVV+c9F/2BWhsiekxU='
[Tue Jan 22 18:06:24 CET 2019] ACCOUNT_THUMBPRINT='rAx6LvYaXQTkGQepmZeT3U93kTVJO0Abw7IsrB_4D18'
[Tue Jan 22 18:06:24 CET 2019] _on_issue_err
[Tue Jan 22 18:06:24 CET 2019] Please check log file for more details: /var/log/acme.sh.log
This clearly did not work, so i tried renewing my certificate on jekare.nl, the staging environment first:
[Tue Jan 22 17:33:59 CET 2019] Using stage ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory
[Tue Jan 22 17:33:59 CET 2019] ACME_DIRECTORY='https://acme-staging.api.letsencrypt.org/directory'
[Tue Jan 22 17:33:59 CET 2019] DOMAIN_PATH='/var/etc/acme-client/home/jekare.nl'
[Tue Jan 22 17:33:59 CET 2019] Using ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory
[Tue Jan 22 17:33:59 CET 2019] _init api for server: https://acme-staging.api.letsencrypt.org/directory
[Tue Jan 22 17:33:59 CET 2019] GET
[Tue Jan 22 17:33:59 CET 2019] url='https://acme-staging.api.letsencrypt.org/directory'
[Tue Jan 22 17:33:59 CET 2019] timeout=
[Tue Jan 22 17:33:59 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:33:59 CET 2019] ret='0'
[Tue Jan 22 17:34:00 CET 2019] ACME_KEY_CHANGE='https://acme-staging.api.letsencrypt.org/acme/key-change'
[Tue Jan 22 17:34:00 CET 2019] ACME_NEW_AUTHZ='https://acme-staging.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 17:34:00 CET 2019] ACME_NEW_ORDER='https://acme-staging.api.letsencrypt.org/acme/new-cert'
[Tue Jan 22 17:34:00 CET 2019] ACME_NEW_ACCOUNT='https://acme-staging.api.letsencrypt.org/acme/new-reg'
[Tue Jan 22 17:34:00 CET 2019] ACME_REVOKE_CERT='https://acme-staging.api.letsencrypt.org/acme/revoke-cert'
[Tue Jan 22 17:34:00 CET 2019] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Tue Jan 22 17:34:00 CET 2019] ACME_NEW_NONCE
[Tue Jan 22 17:34:00 CET 2019] ACME_VERSION
[Tue Jan 22 17:34:00 CET 2019] Le_NextRenewTime='1553258191'
[Tue Jan 22 17:34:00 CET 2019] _on_before_issue
[Tue Jan 22 17:34:00 CET 2019] _chk_main_domain='jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] _chk_alt_domains='www.jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] Le_LocalAddress
[Tue Jan 22 17:34:00 CET 2019] d='jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] Check for domain='jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] _currentRoot='/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:00 CET 2019] d='www.jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] Check for domain='www.jekare.nl'
[Tue Jan 22 17:34:00 CET 2019] _saved_account_key_hash is not changed, skip register account.
[Tue Jan 22 17:34:00 CET 2019] Read key length:4096
[Tue Jan 22 17:34:00 CET 2019] _createcsr
[Tue Jan 22 17:34:00 CET 2019] Multi domain='DNS:jekare.nl,DNS:www.jekare.nl'
[Tue Jan 22 17:34:01 CET 2019] Getting domain auth token for each domain
[Tue Jan 22 17:34:01 CET 2019] d='jekare.nl'
[Tue Jan 22 17:34:01 CET 2019] Getting webroot for domain='jekare.nl'
[Tue Jan 22 17:34:01 CET 2019] _w='/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:01 CET 2019] _currentRoot='/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:01 CET 2019] Getting new-authz for domain='jekare.nl'
[Tue Jan 22 17:34:01 CET 2019] _init api for server: https://acme-staging.api.letsencrypt.org/directory
[Tue Jan 22 17:34:01 CET 2019] Try new-authz for the 0 time.
[Tue Jan 22 17:34:01 CET 2019] url='https://acme-staging.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 17:34:01 CET 2019] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "jekare.nl"}}'
[Tue Jan 22 17:34:01 CET 2019] RSA key
[Tue Jan 22 17:34:04 CET 2019] GET
[Tue Jan 22 17:34:04 CET 2019] url='https://acme-staging.api.letsencrypt.org/directory'
[Tue Jan 22 17:34:04 CET 2019] timeout=
[Tue Jan 22 17:34:04 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:34:04 CET 2019] ret='0'
[Tue Jan 22 17:34:04 CET 2019] POST
[Tue Jan 22 17:34:04 CET 2019] _post_url='https://acme-staging.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 17:34:05 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:34:06 CET 2019] _ret='0'
[Tue Jan 22 17:34:06 CET 2019] code='201'
[Tue Jan 22 17:34:06 CET 2019] The new-authz request is ok.
[Tue Jan 22 17:34:06 CET 2019] entry='"type":"http-01","status":"valid","uri":"https://acme-staging.api.letsencrypt.org/acme/challenge/KQQDbGSAajPtfqHJP8q-YhtEryquN9HsWB6HWKkiJOM/224982980","token":"qt7IUNGVpmTKlffYVfKsMHI9d6fVqlw4qm0XRxhkgYU","validationRecord":[{"url":"http://jekare.nl/.well-known/acme-challenge/qt7IUNGVpmTKlffYVfKsMHI9d6fVqlw4qm0XRxhkgYU","hostname":"jekare.nl","port":"80","addressesResolved":["82.72.7.247"],"addressUsed":"82.72.7.247"'
[Tue Jan 22 17:34:06 CET 2019] token='qt7IUNGVpmTKlffYVfKsMHI9d6fVqlw4qm0XRxhkgYU'
[Tue Jan 22 17:34:06 CET 2019] uri='https://acme-staging.api.letsencrypt.org/acme/challenge/KQQDbGSAajPtfqHJP8q-YhtEryquN9HsWB6HWKkiJOM/224982980'
[Tue Jan 22 17:34:06 CET 2019] keyauthorization='qt7IUNGVpmTKlffYVfKsMHI9d6fVqlw4qm0XRxhkgYU.CTBap2Qw6QOI3KP9jalD1eIM8wUcHXOp7bTwSmUKaew'
[Tue Jan 22 17:34:06 CET 2019] jekare.nl is already verified.
[Tue Jan 22 17:34:06 CET 2019] keyauthorization='verified_ok'
[Tue Jan 22 17:34:06 CET 2019] dvlist='jekare.nl#verified_ok#https://acme-staging.api.letsencrypt.org/acme/challenge/KQQDbGSAajPtfqHJP8q-YhtEryquN9HsWB6HWKkiJOM/224982980#http-01#/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:06 CET 2019] d='www.jekare.nl'
[Tue Jan 22 17:34:06 CET 2019] Getting webroot for domain='www.jekare.nl'
[Tue Jan 22 17:34:06 CET 2019] _w='/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:06 CET 2019] _currentRoot='/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:06 CET 2019] Getting new-authz for domain='www.jekare.nl'
[Tue Jan 22 17:34:06 CET 2019] _init api for server: https://acme-staging.api.letsencrypt.org/directory
[Tue Jan 22 17:34:06 CET 2019] Try new-authz for the 0 time.
[Tue Jan 22 17:34:06 CET 2019] url='https://acme-staging.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 17:34:06 CET 2019] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "www.jekare.nl"}}'
[Tue Jan 22 17:34:06 CET 2019] POST
[Tue Jan 22 17:34:06 CET 2019] _post_url='https://acme-staging.api.letsencrypt.org/acme/new-authz'
[Tue Jan 22 17:34:06 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:34:08 CET 2019] _ret='0'
[Tue Jan 22 17:34:08 CET 2019] code='201'
[Tue Jan 22 17:34:08 CET 2019] The new-authz request is ok.
[Tue Jan 22 17:34:08 CET 2019] entry='"type":"http-01","status":"valid","uri":"https://acme-staging.api.letsencrypt.org/acme/challenge/BeAmaYTvueay_QapeWnvRXlvYuIK4TIu3TN4Qio49UE/224982995","token":"l1vZJtsRZNpqHPUaPl-vlgzYpOdX3IDkfSBpb0RU7Vs","validationRecord":[{"url":"http://www.jekare.nl/.well-known/acme-challenge/l1vZJtsRZNpqHPUaPl-vlgzYpOdX3IDkfSBpb0RU7Vs","hostname":"www.jekare.nl","port":"80","addressesResolved":["82.72.7.247"],"addressUsed":"82.72.7.247"'
[Tue Jan 22 17:34:08 CET 2019] token='l1vZJtsRZNpqHPUaPl-vlgzYpOdX3IDkfSBpb0RU7Vs'
[Tue Jan 22 17:34:08 CET 2019] uri='https://acme-staging.api.letsencrypt.org/acme/challenge/BeAmaYTvueay_QapeWnvRXlvYuIK4TIu3TN4Qio49UE/224982995'
[Tue Jan 22 17:34:08 CET 2019] keyauthorization='l1vZJtsRZNpqHPUaPl-vlgzYpOdX3IDkfSBpb0RU7Vs.CTBap2Qw6QOI3KP9jalD1eIM8wUcHXOp7bTwSmUKaew'
[Tue Jan 22 17:34:08 CET 2019] www.jekare.nl is already verified.
[Tue Jan 22 17:34:08 CET 2019] keyauthorization='verified_ok'
[Tue Jan 22 17:34:08 CET 2019] dvlist='www.jekare.nl#verified_ok#https://acme-staging.api.letsencrypt.org/acme/challenge/BeAmaYTvueay_QapeWnvRXlvYuIK4TIu3TN4Qio49UE/224982995#http-01#/var/etc/acme-client/challenges'
[Tue Jan 22 17:34:08 CET 2019] vlist='jekare.nl#verified_ok#https://acme-staging.api.letsencrypt.org/acme/challenge/KQQDbGSAajPtfqHJP8q-YhtEryquN9HsWB6HWKkiJOM/224982980#http-01#/var/etc/acme-client/challenges,www.jekare.nl#verified_ok#https://acme-staging.api.letsencrypt.org/acme/challenge/BeAmaYTvueay_QapeWnvRXlvYuIK4TIu3TN4Qio49UE/224982995#http-01#/var/etc/acme-client/challenges,'
[Tue Jan 22 17:34:08 CET 2019] d='jekare.nl'
[Tue Jan 22 17:34:08 CET 2019] jekare.nl is already verified, skip http-01.
[Tue Jan 22 17:34:08 CET 2019] d='www.jekare.nl'
[Tue Jan 22 17:34:08 CET 2019] www.jekare.nl is already verified, skip http-01.
[Tue Jan 22 17:34:08 CET 2019] ok, let's start to verify
[Tue Jan 22 17:34:08 CET 2019] pid
[Tue Jan 22 17:34:08 CET 2019] No need to restore nginx, skip.
[Tue Jan 22 17:34:08 CET 2019] _clearupdns
[Tue Jan 22 17:34:08 CET 2019] skip dns.
[Tue Jan 22 17:34:08 CET 2019] Verify finished, start to sign.
[Tue Jan 22 17:34:09 CET 2019] i='2'
[Tue Jan 22 17:34:09 CET 2019] j='26'
[Tue Jan 22 17:34:09 CET 2019] url='https://acme-staging.api.letsencrypt.org/acme/new-cert'
[Tue Jan 22 17:34:09 CET 2019] payload='{"resource": "new-cert", "csr": "MIIEnDCCAoQCAQAwFDESMBAGA1UEAwwJamVrYXJlLm5sMIICIjANBgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAlqx7WDeBZo0fyXds1b-9psc9uAWzciTbLnR7WzU2Z_Ahi4lqcxPHjtKOoZFF2a634NS3gBXMII7jdER7LQhnNwEWJOjg4nrSCUII4Fi63P5_H8_0VFS-93PNJ7qyEMVvmpJW3Ax8EjJ2f8ncLR0I4P2paf0S66tmsu_vzNhcrLL9rBOw-O7w5eH7UfYbaz6WrDfxJO6h0r-YyE83vcA82lOvCPdpP96DSYs-6ZCXeIu4OdVharU6Z90WV7yPsJ3ermvKijmbVCk9YYFMnMqh3ARG9U79PYGzd-K_SpAgt07TdfwWJPJ2-rxY7AdvkGFOwGPZ1zj-Ajiy1lSTQCGfU_H7d9IcTy7diJUTh46dSZIg3CGiaOpdgx7k40IUVj_s2UDRV4YMcxCc8XkTvPosp5ArcP9-WmlFxJ_yyiM4BGHmExNaYDKMPfq3bbYEw0JZrsJWiojD8ukolCtYKpO_pGvNxZwTBpXF7SSzFWQftK3PHzKLdh6xBNSi6f6X_Yk6HwyAtmiksuQ1W5NHEk5uIE8Tijp1p43UtMYpO79SGSxqul1lkv7JaQz5N3BcZlREHK0eI2_cfC7j2zSxq2E1xE8mpL6RexD9FOX0vKwrXXgSZdzAs53NUWV-RY08WvPHhEXpVfSOp9en9fmO47RmIqnkrw3DJq-BcjV7hyFIldUCAwEAAaBDMEEGCSqGSIb3DQEJDjE0MDIwCwYDVR0PBAQDAgXgMCMGA1UdEQQcMBqCCWpla2FyZS5ubIINd3d3Lmpla2FyZS5ubDANBgkqhkiG9w0BAQsFAAOCAgEAa6ZHOZu7OSwR-iJ5AcyV28QPqouCBh0u8vUtn6zoEYz8KSNDmI2NqM7L-boJGEGA599XRm-vpaD7KsnGQv1XArxn9GDb6zK4Ch2SCDyVM2-C81_rBddfdJfxBZyEpKkXNLQpg2GKlXDZZlGmCWrCwvk9PlZ3h8t02-Ri4CdrvwrwoTIh53c0q_kC0m-QxessZRAxTb5BZgSGExDEf6AqSda7xPfZLoKny-FCZAW8kYB9LvvR8831BEUXTfZJNwlzzzgM6oN4K2VtZL4e4-8WWOLhgEpTOHXRteqxK0MlhoGKMl1_DZP6n9yH2_H7YNJhUZwsDWh2cvOJdZnJKtcBJj5i-sOJLyIC_-JV772aSNelcphU2dQqV0bgrwFNZV0tUcJyWIAHsivkNIDWWwIgRr14c7LV2z4mQNgMDTuM675hQV5jEP5xKM8mS-fIKY3JPV06PAV0Kc1Yi3QAuL7gbjJ8wbNnxgqNEn9FJPbG77DhHBwgu57TKjYh_VdXEALAh_DJIK2P2c4qkzj6asVNDja0xg5RxWRZo0u6rra8SLnoUYFHWpWh6hDKZEnbVtbExvb1u9HydGp5d8IYwIeWNUnoi18nA7BA333uaAb4y-cFlOLciepXMENQ07hZFAohI-bvjYxXf6ucb75uAOYKPRK5gB0dVa3FU1JuPE4luNs"}'
[Tue Jan 22 17:34:09 CET 2019] POST
[Tue Jan 22 17:34:09 CET 2019] _post_url='https://acme-staging.api.letsencrypt.org/acme/new-cert'
[Tue Jan 22 17:34:09 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:34:12 CET 2019] _ret='0'
[Tue Jan 22 17:34:12 CET 2019] code='201'
[Tue Jan 22 17:34:12 CET 2019] Le_LinkCert='https://acme-staging.api.letsencrypt.org/acme/cert/fa046915dcb6c7972a8e58deb25a7a532945'
[Tue Jan 22 17:34:12 CET 2019] Cert success.
[Tue Jan 22 17:34:12 CET 2019] Your cert is in /var/etc/acme-client/home/jekare.nl/jekare.nl.cer
[Tue Jan 22 17:34:12 CET 2019] Your cert key is in /var/etc/acme-client/home/jekare.nl/jekare.nl.key
[Tue Jan 22 17:34:12 CET 2019] Le_LinkIssuer='https://acme-staging.api.letsencrypt.org/acme/issuer-cert'
[Tue Jan 22 17:34:12 CET 2019] _link_issuer_retry='0'
[Tue Jan 22 17:34:12 CET 2019] GET
[Tue Jan 22 17:34:12 CET 2019] url='https://acme-staging.api.letsencrypt.org/acme/issuer-cert'
[Tue Jan 22 17:34:12 CET 2019] timeout=
[Tue Jan 22 17:34:12 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 17:34:13 CET 2019] ret='0'
[Tue Jan 22 17:34:13 CET 2019] The intermediate CA cert is in /var/etc/acme-client/home/jekare.nl/ca.cer
[Tue Jan 22 17:34:13 CET 2019] And the full chain certs is there: /var/etc/acme-client/home/jekare.nl/fullchain.cer
[Tue Jan 22 17:34:13 CET 2019] Installing cert to:/var/etc/acme-client/certs/5c439d3f40b355.63681904/cert.pem
[Tue Jan 22 17:34:13 CET 2019] Installing CA to:/var/etc/acme-client/certs/5c439d3f40b355.63681904/chain.pem
[Tue Jan 22 17:34:14 CET 2019] Installing key to:/var/etc/acme-client/keys/5c439d3f40b355.63681904/private.key
[Tue Jan 22 17:34:14 CET 2019] Installing full chain to:/var/etc/acme-client/certs/5c439d3f40b355.63681904/fullchain.pem
[Tue Jan 22 17:34:14 CET 2019] _on_issue_success
this all looked good, so i tried the renewal via the production environment:
[Tue Jan 22 15:38:44 CET 2019] GET
[Tue Jan 22 15:38:44 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:44 CET 2019] timeout=
[Tue Jan 22 15:38:44 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:45 CET 2019] ret='0'
[Tue Jan 22 15:38:45 CET 2019] Pending
[Tue Jan 22 15:38:45 CET 2019] sleep 2 secs to verify
[Tue Jan 22 15:38:47 CET 2019] checking
[Tue Jan 22 15:38:47 CET 2019] GET
[Tue Jan 22 15:38:47 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:47 CET 2019] timeout=
[Tue Jan 22 15:38:47 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:47 CET 2019] ret='0'
[Tue Jan 22 15:38:47 CET 2019] Pending
[Tue Jan 22 15:38:47 CET 2019] sleep 2 secs to verify
[Tue Jan 22 15:38:50 CET 2019] checking
[Tue Jan 22 15:38:50 CET 2019] GET
[Tue Jan 22 15:38:50 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:50 CET 2019] timeout=
[Tue Jan 22 15:38:50 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:50 CET 2019] ret='0'
[Tue Jan 22 15:38:50 CET 2019] Pending
[Tue Jan 22 15:38:50 CET 2019] sleep 2 secs to verify
[Tue Jan 22 15:38:52 CET 2019] checking
[Tue Jan 22 15:38:52 CET 2019] GET
[Tue Jan 22 15:38:52 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:52 CET 2019] timeout=
[Tue Jan 22 15:38:52 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:53 CET 2019] ret='0'
[Tue Jan 22 15:38:53 CET 2019] jekare.nl:Verify error:Fetching http://jekare.nl/.well-known/acme-challenge/4frjuk-A8aGExROSjbxR79ztuNx-bx_bj8Oc-bYHED0: Timeout during connect (likely firewall problem)
[Tue Jan 22 15:38:53 CET 2019] pid
[Tue Jan 22 15:38:53 CET 2019] No need to restore nginx, skip.
[Tue Jan 22 15:38:53 CET 2019] _clearupdns
[Tue Jan 22 15:38:53 CET 2019] skip dns.
[Tue Jan 22 15:38:53 CET 2019] _on_issue_err
[Tue Jan 22 15:38:53 CET 2019] Please check log file for more details: /var/log/acme.sh.log
[Tue Jan 22 15:38:53 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:53 CET 2019] payload='{"resource": "challenge", "keyAuthorization": "4frjuk-A8aGExROSjbxR79ztuNx-bx_bj8Oc-bYHED0.CTBap2Qw6QOI3KP9jalD1eIM8wUcHXOp7bTwSmUKaew"}'
[Tue Jan 22 15:38:53 CET 2019] POST
[Tue Jan 22 15:38:53 CET 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/WpddvMu-xX0vbQoMiRSKG1DSmNQ06GTv64dStXfESXM/11747361546'
[Tue Jan 22 15:38:53 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:54 CET 2019] _ret='0'
[Tue Jan 22 15:38:54 CET 2019] code='400'
[Tue Jan 22 15:38:54 CET 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/RvPWoA-Gz3N1kCmbDI3hZhaojtkvDoJF6MYdIFzDAUs/11747362027'
[Tue Jan 22 15:38:54 CET 2019] payload='{"resource": "challenge", "keyAuthorization": "ABssaR7E4ctGgZs8zo81Bc8Skb3PBIuZz84qLftFd24.CTBap2Qw6QOI3KP9jalD1eIM8wUcHXOp7bTwSmUKaew"}'
[Tue Jan 22 15:38:54 CET 2019] POST
[Tue Jan 22 15:38:54 CET 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/RvPWoA-Gz3N1kCmbDI3hZhaojtkvDoJF6MYdIFzDAUs/11747362027'
[Tue Jan 22 15:38:54 CET 2019] _CURL='curl -L --silent --dump-header /var/etc/acme-client/home/http.header -g '
[Tue Jan 22 15:38:55 CET 2019] _ret='0'
[Tue Jan 22 15:38:55 CET 2019] code='202'
Now it suddenly says Timeout during connect (likely firewall problem), but nothing changed in the router/firewall. I don't understand this.
HAProxy HTTP frontend (part of HAProxy plugin)
OPNsense v18.7.10
- Let's Encrypt plugin v1.18
- HAProxy plugin v2.13
yes, to get to the config files and logs, but can't install certbot and don't know how to run the acme.sh script manually nor if it is even possible.
OPNsense GUI.
