Can certificate be revoked and re-issued using Certbot on Ubuntu 18.04?
Hello,
I successfully installed Let’s Encrypt certificate for a domain using Certbot for Apache on Ubuntu 18.04. It was done for the domain part name, i.e example.com. But I was wondering if it can be revoked and done for www.example.com instead of example.com that was initially done for. Thank you.
Well, yes, it can be revoked, but it shouldn’t be. Just issue a new cert with the correct names on it.
Thank you. I appreciate that.
