Caddy: repeated DNS networking errors during secondary validation (Cloudflare DNS)
Hello,
I need help diagnosing repeated DNS errors during initial certificate issuance for mahjong-staging.conzula.com. This is the actual domain, not a placeholder.
Environment
Errors and timing
The initial failures were recorded on 20 October 2026, approximately 00:10:48–00:12:09 UTC. The same error was reproduced in a later, bounded test on the same date.
The relevant ACME problem details are:
During secondary validation: DNS problem: networking error looking up A for mahjong-staging.conzula.com; DNS problem: networking error looking up AAAA for mahjong-staging.conzula.com
During secondary validation: While processing CAA for mahjong-staging.conzula.com: DNS problem: networking error looking up CAA for mahjong-staging.conzula.com
Earlier Caddy logs showed failures involving both HTTP-01 and TLS-ALPN-01. A later test using only a temporary static Caddy site, without any application backend, reproduced the A/AAAA networking error.
Checks already completed
  • Both authoritative nameservers returned the expected A record.
  • Queries through 1.1.1.1 and 8.8.8.8 also returned the expected A record.
  • AAAA queries returned NOERROR with no AAAA records.
  • CAA queries for both mahjong-staging.conzula.com and conzula.com returned NOERROR with no CAA records.
  • A delegation trace confirmed the expected Cloudflare nameservers.
  • A DS query through 1.1.1.1 returned NOERROR with no DS records.
These checks succeeded from our locations; we understand that this does not establish what every secondary validation perspective can reach.
Current state
We have stopped issuance attempts to avoid repeated failures and rate limits. The temporary Mahjong site configuration was removed after the failed test, restoring the previous proxy configuration.
Therefore, a missing certificate or failed TLS handshake for this hostname now is expected: the temporary site is no longer configured. No valid public certificate was verified.
Could you help determine whether this error indicates a problem between a secondary validator and its DNS resolver, or suggest further checks on our side?
Please let us know which specific diagnostic details or failed authorization references would help. We can collect targeted, sanitized output without sharing private keys, credentials, or complete server configurations.
Thank you.
Let's Encrypt Status says that Let's Encrypt started to investigate "elevated rates of validation failures" at 00:28 UTC. Maybe that could be the cause? The issue was resolved at 00:54 UTC.
DNSSEC Debugger - conzula.com
I would have thought all domains hosted by CF would be DNSSEC signed.
  1. DNSSEC is optional in cloudflare
  2. That tool is just reporting that the domain is unsigned (insecure in DNSSEC terms), this just means that DNSSEC is not protecting your domain's DNS records. However it's still resolvable by DNSSEC validating and DNSSEC unaware resolvers.
So... it's just a checkbox [not the default] - got it.
