Browser error using secured site
Hi there.
I have just created an SSL certificate using your services - wow was that easy (thank you for that!). I’m running an Ubuntu Server with Apache2 redirecting to Tomcat 8 for site content. But when I navigate to my new site, some portions will not show up. In my browser (Chrome but similar on Firefox) I see a shield icon in the URL bar with the following error:
“This page is trying to load scripts from unauthenticated sources”.
I am given the option to “load unsafe scripts” but I would prefer my users not to have to look for this - they’ll never see the shield. What can I do? In /etc/apache2/sites-available/ I had a conf file for my site and a new file was created (ending -le.ssl.conf) … I append them here:
myapp.example.com.conf:
# domain: myapp.example.com
# public: /var/lib/tomcat8/webapps/myapp
<VirtualHost *:80>
ServerName myapp.example.com
ProxyRequests Off
ProxyPass / http://localhost:8080/myapp/
ProxyPassReverse / http://localhost:8080/myapp/
ProxyPassReverseCookiePath /myapp /
ProxyPreserveHost On
RewriteEngine on
RewriteCond %{SERVER_NAME} =myapp.example.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
</VirtualHost>
myapp.example.com-le-ssl.conf:
<IfModule mod_ssl.c>
<VirtualHost *:443>
ProxyRequests Off
SSLCertificateFile /etc/letsencrypt/live/example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/example.com/privkey.pem
</VirtualHost>
</IfModule>
Is there any way I can configure the site to just work without any browser warnings? Thanks very much.
@thestoat
usually I would ask for domain but you seem to know what you are doing
https://www.whynopadlock.com/
will analyse your site and give you the insecure components :smiley:
sometimes it’s thing like CDNs and images
Andrei
Wow! Thank you for that, Andrei (and for the vote of confidence - I know bits but I’m more a developer with a little knowhow, which is usually a dangerous thing). In my code I was including links like
http://ajax.googleapis.com/ajax/libs/jqueryui/1.8/jquery-ui.min.js
When I altered those to
https://ajax.googleapis.com/ajax/libs/jqueryui/1.8/jquery-ui.min.js
the site you mentioned stopped complaining at me and all seems to work fine. Once again - thank you :smiley:
You can use the format of "//ajax.google..". (i.e., without specifying either http nor https) to let the browser choose the protocol. When the site is loaded through http, the browser will use http for that resource, if the browser uses https for the site, it uses https for the resource too :slight_smile:
But using https:// for a HTTPS only site works too of course :wink:
There’s always so much to learn. But thank you for the hint, Osiris. Good to know :smiley:
