My domain is: https://jakzaizzat.com/
I ran this command: certbot --nginx -d jakzaizzat.com -d www.jakzaizzat.com
Could not open file: /etc/nginx/sites-enabled/defaultWhat would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/jakzaizzat
Please choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP access.- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Congratulations! You have successfully enabled https://jakzaizzat.com and
https://www.jakzaizzat.com
You should test your configuration at:https://www.ssllabs.com/ssltest/analyze.html?d=jakzaizzat.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.jakzaizzat.com
My web server is (include version): nginx 1.10.3
The operating system my web server runs on is (include version): ubuntu 16
My hosting provider, if applicable, is: linode
no
or certbot-auto --version
if you’re using Certbot): 0.31.0
When I browse to the webpage it is blank.
when I browse to the http version the page loads http://172.104.163.141/
