Hello,
Currently I generated the certificates and everything is working fine.
- I generated SAN certificates in server A using docker run cmd and certificates are generated in /etc/letsencrypt/live/$domain
- Stored those certificates in server B(Repo server)
- Then copy those certificates from server B to server C(its our production server)
Can someone help me to elaborate how to effectively manage the certificates. currently I am doing this
- When the certificates are to be expired , a certificate renew request is sent to letsencrypt and receive the new certificates.
- Again copy those certificates to Server B
- Stop NGINX in server C , copy the cert from server B and then start nginx again
The above looks bit cumbersome . Can someone share how they managed in the production environment
quantiply.com
docker run -it --rm -v /docker-volumes/etc/letsencrypt:/etc/letsencrypt -v /docker-volumes/var/lib/letsencrypt:/var/lib/letsencrypt -v /docker/letsencrypt-docker-nginx/src/letsencrypt/letsencrypt-site:/data/letsencrypt -v “/docker-volumes/var/log/letsencrypt:/var/log/letsencrypt” certbot/certbot certonly --webroot --agree-tos --no-eff-email --webroot-path=/data/letsencrypt -d $host_name -d
Congratulations. Certificates generated successfully
nginx -1.14.2-1.el7_4
CentOS Linux release 7.6.1810
no
or certbot-auto --version
if you’re using Certbot):
0.29.1
