Axigen and Let's Encrypt
Has anyone used Axigen mail server with Let’s Encrypt? I’m attempting, but so far it isn’t working.
So far the best instruction I’ve found is here: https://www.axigen.com/forum/forum/support-discussion-lists/general-configuration/22720-using-let-s-encrypt-with-axigen?p=22732#post22732. Which I’ve tried doing but I got an error in the browser “SSL_ERROR_RX_RECORD_TOO_LONG”
Does anyone have any suggestions?
The SSL_ERROR_RX_RECORD_TOO_LONG error almost always means that the server is speaking HTTP rather than HTTPS on the specified port. I don’t know how to fix that with Axigen, but maybe knowing that that is what it means will help for debugging.
The combining of the files worked. I had to enable port 443 in the web mail settings on Axigen. Thanks~
