My domain is: remote.ccrclimited.net
I ran this command: Get Certificate in the Axcient Vault Setup
It produced this output: "Failed to sign / renew certificate - Please check the URL and try again"
My web server is (include version): Axcient Vault Software 14.1.1
The operating system my web server runs on is (include version): Ubuntu base
My hosting provider, if applicable, is: Self on dedicate external static IP
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): The built in panel
or certbot-auto --version
if you're using Certbot): unk
Have loaded Axcient Vault software 14.1.1 Last step is to get a Let's Encrypt certificate. Have enabled Diect to Cloud. Certificate get returns "Failed to sign / renew certificate. Please check the URL and try again."
Have verified 80 and 443 port directly to the server internal IP. Server can be reached externally on both http and https, (with a warning for self signed).
Asking for some guidance please before doing a deep dive into the firewall.
THANK YOU FOR READING!!
