Automate SSL renewal for AL2023 LightSAIL
provision.domains
The operating system my web server runs on is lightsail AL2023
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):NO
Automate letsEncrypt SSL cert for Lightsail AL2023
Given: I have al2023 installed under LIGHTSAIL.
I have a LetsEcnrypt ssl cert and it works.
AL2023 no longer uses cron
I believe I could install it, but wonder if it will be stable? I have read something about a system timer? over Cron? I want to automate renewals of my Let'sEncrypt cert
Problem: I am not sure how to automate my ssl cert "renewal" under Lightsail AL2023 Thanks
The search key you're probably looking for is "systemd timer".
Thanks systemd timer noted :blush:
