Auto-renew with certbot without stopping my nodejs server
OK, HTTP [IPv4] redirects to HTTPS.
[IPv4] HTTPS seems to return something.
I think the problem is just IPv6.
Why do you have an IPv6 address in DNS?:
[it doesn't seem to be served by nodejs]
Addresses: 2a01:4f8:c2c:ea35::1
           188.245.74.241
this error goes away if i stop the http redirecting to https
yeah it isnt, should I make it handel them?
False sense of accomplishment.
Doing that doesn't really fix anything,
It only makes the test think that it could work because it doesn't fail outright.
Pick one [your choice]:
  • use IPv6 in DNS and serve the IPv6 requests
  • remove the IPv6 from DNS [no requests to serve]
ive removed the ipv6 from the DNS now
there seems to be no errors on the Lets Debug thing now, but the renew still errors the same
Good choice.
:+1:
What is the command you ran?
What was the webroot used?
sudo certbot renew --dry-run
The webroot must match the path [minus the /.well-known/acme-challenge/ part].
where is the webroot
Where did you put that "file.txt" file?
inside acme-challenge
Well, that would be the FULL path.
The webroot is that same FULL path minus the /.well-known/acmne-challenge/ part.
[that part gets automatically added by the acme client]
yeah but like where actually do I input the webroot
certbot certonly -webroot -w /path/to/where/ever/that/is -d jumblgram.com -d www.jumblgram.com
User Guide — Certbot 2.12.0.dev0 documentation (eff-certbot.readthedocs.io)
so the path would just be /file.txt
What is that entire path [on the disk]?
You are confusing the HTTP request path with where the files are located on the disk PATH.
Use:
