syntax error near unexpected token ‘random.random’
That error happens when a Python program is executed by bash instead of Python.
or certbot-auto --version
if you’re using Certbot):
www.milton-chocolate.nl
i ran standard auto renew cron script from certbot page for macos
i get syntax errors within python when i run the exact script on the site
apache webserver 2.4.33
macOS 10.13.6
i can login to root shell
no control panel
certbot 0.34.2
What is that script?
What are those errors?
echo “0 0,12 * * * root python -c ‘import random; import time; time.sleep(random.random() * 3600)’ && certbot renew” | sudo tee -a /etc/crontab > /dev/null
funny i tried the same copy paste i used for your reply and now the shell likes the above mentioned script without errors it just asked me for my password and executed and i m back at prompt !
thank you for your effort time and patience ! regards milton case can be closed
