I had to reinstall Linux and the usual headaches apply
got my site uploaded, loaded the database
installed apache2 and activated but cannot get it working
not sure how messy the setup is, save the conf file for my site earlier to I cp it to /etc/apache2/sites-available so that it would be ready
anyway nothing conspicuous as to certbot or apache to bring the site back up
griffin
2
Use this:
sudo a2ensite mysite.com.conf
sudo apachectl -k graceful
first thing i did, site not providing a secure connection
on testing the default page works so that is know to be working
sudo a2ensite hardcoregames.ca.conf
Site hardcoregames.ca already enabled
This site can’t provide a secure connection
www.hardcoregames.ca sent an invalid response.
- [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
rg305
4
What shows?:
apachectl -S
JimPas
5
Here is the error message I get when trying to access hardcoregames.ca:
Your PHP installation appears to be missing the MySQL extension which is required by WordPress.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80 www.hardcoregames.ca (/etc/apache2/sites-enabled/hardcoregames.ca.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Hi @HardcoreGames
there is no non-www visible. Add that.
Then fix the error message @JimPas has reported.
this was working before fine
<VirtualHost *:80>
ServerName www.hardcoregames.ca
ServerAlias hardcoregames.ca
DocumentRoot /var/www/hardcoregames.ca
</VirtualHost>
It seems that the Apache vhost is at issue so I am able to get the default apache page rendering but vhost is being ignored
finally brought the site up, messy as usual but the database does not seem to be the problem now it seems to be more the themes messy practices
I changed the vhost file a tad and then after cleaning the database ad naueum I was able to get the certificate workin
some update must have broken it from the last attempt to fix the database
it seems now that JetPack is borked so I guess it's time to so more database cleaning
permalinks are working now at last
system
Closed
12
