Apache throws 403
Try using the test/staging environment:
--dry-run
It's never one full hour.
The wait is until 5 turns to 4 within the last hour.
Same 403
PHP is killing the ACME requests!
How can it tell the difference between my requests and the LE requests?????
Mine get through, LE gets 403.
run it in debug again and save a copy of the temp file created
we can then use that file to test with after certbot ends
My brain is starting a meltdown...
I'll have to cool it off to continue :beer:
Saved. Saved also the pre and post.conf in /etc/apache2
It’s 2:21 AM here, i’m also not really able to think anymore :slight_smile: Perhaps we’ll continue tomorrow? It’s no production server, no costs involved :slight_smile:
In le_http_01_challenge_post.conf is the missed directory directive:
 <Directory /var/lib/letsencrypt/http_challenges>
            Require all granted
        </Directory>
        <Location /.well-known/acme-challenge>
            Require all granted
        </Location>
After a night’s sleep, i’m still convinced that the files are created with wrong permissions. Is there a way to test this, i.e. keep the challenge files instead of have them deleted?
--debug-challenges
It worked with certbot run -a webroot -i apache -w /srv/phpmyadmin_html -d pmadmin.qno.de so it seems it is not a misconfiguration but a problem with the apache authentiication plugin. I will watch this thread still some days to help with debugging.
Thank you, happy holydays.
I don't see how this would work:
and this would not work:
To me, something else must have changed.
You are perfectly right. But i did not change something else, and i would not know of another admin.
Try both in staging:
certbot run -a webroot -i apache -w /srv/phpmyadmin_html -d pmadmin.qno.de --dry-run
certbot certonly --webroot -w /srv/phpmyadmin_html -d pmadmin.qno.de --dry-run
There are only three possible outcomes:
  • both work:
    goes to my assertion of the "something else" changed
  • only one works
    highly unlikely...
    but might indicate that the two commands aren't as equal as they appear to be
  • neither of them works.
    this indicates that something new has changed and now breaks it all
