Let's have a look at this file:
/etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
</VirtualHost>
If you aren't using that vhost config file, please disable its' use.
a2dissite /etc/apache2/sites-enabled/000-default.conf
OR
At least, use a ServerName in it:
[use a name that you would never serve - like: ServerName not-for-use]
Disabled now. Same result.
What does the Apache error log file show us?
Place a test text file in that challenge location:
echo "test" /srv/phpmyadmin_html/.well-known/acme-challenge/Test_File-1234
Then we try:
http://pmadmin.qno.de/.well-known/acme-challenge/Test_File-1234
From apache2 error.log:
[Tue Dec 19 01:49:24.285268 2023] [mpm_prefork:notice] [pid 847586] AH00171: Graceful restart requested, doing restart
[Tue Dec 19 01:49:24.301882 2023] [mpm_prefork:notice] [pid 847586] AH00163: Apache/2.4.52 (Ubuntu) OpenSSL/3.0.2 configured -- resuming normal operations
[Tue Dec 19 01:49:24.301891 2023] [core:notice] [pid 847586] AH00094: Command line: '/usr/sbin/apache2'
[Tue Dec 19 01:49:29.590890 2023] [mpm_prefork:notice] [pid 847586] AH00171: Graceful restart requested, doing restart
[Tue Dec 19 01:49:29.609858 2023] [mpm_prefork:notice] [pid 847586] AH00163: Apache/2.4.52 (Ubuntu) OpenSSL/3.0.2 configured -- resuming normal operations
[Tue Dec 19 01:49:29.609871 2023] [core:notice] [pid 847586] AH00094: Command line: '/usr/sbin/apache2'
From phpmyadmins error.log:
[Tue Dec 19 01:49:28.791132 2023] [core:error] [pid 895364] (13)Permission denied: [client 2600:1f16:269:da02:4906:1c01:c613:b698:18948] AH00035: access to /.well-known/acme-challenge/X9pKM0GuSYsyaCyYfiOjIC9iR_ia9azny9xduMqNrkw denied (filesystem path '/var/lib/letsencrypt/http_challenges') because search permissions are missing on a component of the path
[Tue Dec 19 01:49:29.141287 2023] [core:error] [pid 895365] (13)Permission denied: [client 2600:3000:1511:200::85:57681] AH00035: access to /.well-known/acme-challenge/X9pKM0GuSYsyaCyYfiOjIC9iR_ia9azny9xduMqNrkw denied (filesystem path '/var/lib/letsencrypt/http_challenges') because search permissions are missing on a component of the path
[Tue Dec 19 01:49:29.191480 2023] [core:error] [pid 895367] (13)Permission denied: [client 2600:1f14:804:fd01:c0ba:2a71:c2ef:8fa9:52726] AH00035: access to /.well-known/acme-challenge/X9pKM0GuSYsyaCyYfiOjIC9iR_ia9azny9xduMqNrkw denied (filesystem path '/var/lib/letsencrypt/http_challenges') because search permissions are missing on a component of the path
Done now
Well there is the problem!
PHP no likey!
certbot is run as root, and root makes new files with root:root 640
In the path, everything has www-data:www-data u+rw(x) g+r(x) o-rwx
-v plz
Where is this in your Apache config?:
How does this work?????
curl http://pmadmin.qno.de/.well-known/acme-challenge/Test_File-1234
test
Isn't that file also root:root ???
Changed the file to www-data:www-data
Please don't make changes without saying anything - that is not good teamwork ![]()
I'm trying to help you.
You need to help me help you.
I don't get paid by the hour and want this to take longer so I can charge you more - LOL
I volunteer my time here FOR FREE - so, I want this to go quickly!
Nowhere. Now that you mention this, i understand why it should be there. But where? Why isn’t it in /etc/letsencrypt/options-ssl-apache.conf? And i do not find it in the docs.
grep for it within the apache directory - it must exist somewhere!
also check:
set | grep -i challenges
Maybe it exists somewhere in PHP ? ? ?
root@bywater /etc/apache2 # find . -exec grep /var/lib/letsencrypt {} \; -print
shows all dirs and files but no match.
empty
I added to a02-phpmyadmin.conf
<Directory /var/lib/letsencrypt/http_challenges>
AllowOverride All
Require all granted
</Directory>
And now i have too much requests and have to wait for an hour or so ![]()
