My domain is: www.journeyman.cc
I ran this command: service apache2 restart
It produced this output: (none)
My web server is (include version): apache2 2.4.61-1~deb12u1
The operating system my web server runs on is (include version): Linux notary 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64 GNU/Linux
My hosting provider, if applicable, is: Linode
or certbot-auto --version
if you're using Certbot): certbot 2.1.0
Problem description
OK, this is not strictly a certbot problem, it's a certbot-adjacent problem. And it's entirely my fault, I deserve no sympathy. But I've messed up my SSL config, and, ironically, I messed it up trying to tighten security.
The default-le-ssl.conf
was generated by certbot; it worked. I added a stanza to enable webgit, that worked. I did not keep a copy of the last known-good config. I then tried to password protect webgit, and the default site ceased to serve at all on HTTPS (still serves on HTTP). Apache reports no errors, not even in the log:
root@notary:/etc/apache2/sites-available# apachectl configtest
Syntax OK
root@notary:/etc/apache2/sites-available# service apache2 restart
root@notary:/etc/apache2/sites-available# root@notary:/etc/apache2/sites-available# tail /var/log/apache2/error.log
[Wed Sep 18 08:16:34.773990 2024] [mpm_prefork:notice] [pid 3549146:tid 3549146] AH00170: caught SIGWINCH, shutting down gracefully
[Wed Sep 18 08:16:34.855549 2024] [mpm_prefork:notice] [pid 3549557:tid 3549557] AH00163: Apache/2.4.61 (Debian) mod_jk/1.2.48 OpenSSL/3.0.13 configured -- resuming normal operations
[Wed Sep 18 08:16:34.855651 2024] [core:notice] [pid 3549557:tid 3549557] AH00094: Command line: '/usr/sbin/apache2'
I then commented out the entire gitweb stanza, but this made no difference: same absolute lack of any diagnostic errors or log entries.
Attempting to rerun certbot to regenerate default-le-ssl.conf
fails as follows:
root@notary:/etc/apache2/sites-available# certbot --apache -v -d notary.journeyman.cc -d www.journeyman.cc
(ref: /etc/letsencrypt/renewal/notary.journeyman.cc.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Deploying certificate
Could not install certificate
An unexpected error occurred:
StopIteration
(a very similar failure occurs when I attempt Renew & replace the certificate (may be subject to CA rate limits)
The full default-le-ssl.conf
, as it stands now, is as follows:
<VirtualHost *:80>
ServerAdmin simon@journeyman.cc
ServerName notary.journeyman.cc
ServerAlias www.journeyman.cc
DocumentRoot /var/www/http
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/http>
Require all granted
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
Alias /awstatsclasses "/usr/share/awstats/lib/"
Alias /awstats-icon/ "/usr/share/awstats/icon/"
Alias /awstatscss "/usr/share/doc/awstats/examples/css"
ScriptAlias /awstats/ /usr/lib/cgi-bin/
# Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
RewriteEngine on
RewriteCond %{HTTPS} off
<IfModule headers_module>
header set X-Falling-Outside-the-Normal-Moral-Constraints "Ia\
in M Banks"
header set X-Lambda "λάμβδα"
</IfModule>
# RewriteCond %{SERVER_NAME} =projecthope.scot [OR]
# RewriteCond %{SERVER_NAME} =www.projecthope.scot
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
# Alias /gitweb "/usr/share/gitweb"
# <Directory "/usr/share/gitweb">
# <IfModule mod_auth_digest>
# AuthType Digest
# AuthName "Journeyman"
# AuthDigestProvider file
# AuthUserFile "/etc/apache2/auth/passwords"
# AuthGroupFile "/etc/apache2/auth/groups"
# Require group git
# </IfModule>
# DirectoryIndex gitweb.cgi
# Options ExecCGI
# Require all granted
# <Files gitweb.cgi>
# SetHandler cgi-script
# </Files>
# SetEnv GITWEB_CONFIG /etc/gitweb.conf
# </Directory>
</VirtualHost>
Any suggestions gratefully received!
