Anyone have details of how to integrate ACME with Avaya enterprise systems, call center, etc.
My domain is: avaya
I ran this command: n/a
Hello @jhoeg,
That is not a complete domain name.
See Domain name - Wikipedia
That's really a support question for Avaya, since you are likely paying them a lot for that, however getting a cert and using it are two different things often done at the same time:
  • Use an ACME software tool to get the certificate you need to cover the fully qualified name of your service e.g. something.yourdomain.com. You can't get publicly trusted certs for internal names unless they are fully qualified with the domain. Which ACME client depends largely on what's already being used in your organization (if you are "enterprise" you likely already have hundreds of certs happening) and tho some extent which operating systems you are using.
  • Using a cert (deployment) is the act of applying a certificate to a service, usually as one or more component files, the service typically loads the certificate file and uses it for TLS conversations. Often (but not always) services need restarted after a new certificate is applied, some more capable services can dynamically load the latest cert without restarting.
Note that it's not clear from your question whether you are a seasoned IT professional, a non-IT person or if you've just finished high school, so we don't know at what technical level to pitch the answers.
