My domain is: regix.tk / panel.regix.tk
I ran this command: certbot certonly --apache -d panel.regix.tk
(ref: /etc/letsencrypt/renewal/panel.regix.tk.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for panel.regix.tk
Certificate is saved at: /etc/letsencrypt/live/panel.regix.tk/fullchain.pem
Key is saved at: /etc/letsencrypt/live/panel.regix.tk/privkey.pem
This certificate expires on 2022-11-15.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
An unexpected error occurred:
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='supporters.eff.org', port=443): Max retries exceeded with url: /subscribe/certbot (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f1b1a1e28c0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
My web server is (include version): The latest ubuntu with apache
The operating system my web server runs on is (include version): Ubuntu latest
My hosting provider, if applicable, is: cloudflare and me
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): PuTTY
or certbot-auto --version
if you're using Certbot): certbot 1.21.0
