Resultados de la verificación
Tengo un problema, llevo varias veces intentando instalar el certificado ssl y me sale este error después de añadir los archivos en la carpeta y subcarpeta indicada.
Algunos dominios han fallado la verificación. Comprueba la lista y luego pulsa "Siguiente" para repetir la verificación. Nota: El código de verificación será diferente.
Alguien me puede ayudar con este problema por favor.
Hi @eduardomv
that's
eduardomv:
src = aes.js
a known blocking script. It's something like a bot detection. So Letsencrypt can't validate your domain, so you can't use http validation.
Checking your domain - https://check-your-website.server-daten.de/?q=dmarketingem.com - Grade J:
Fatal: Script /aes.js found. Looks like your hoster has a Bot-Check-Detection, so Letsencrypt can't check your http-validation file.
If you hoster has installed that script -> you can't use Letsencrypt with http validation.
If you have installed that script -> remove it.
PS: If it is possible, use dns challenge.
When you get a certificate from Let’s Encrypt, our servers validate that you control the domain names in that certificate using “challenges,” as defined by the ACME standard. Most of the time, this validation is handled automatically by your ACME...
But it's required that your name server allows to create TXT entries.
If your hoster installs such a script, it may be impossible to install an own certificate.
system
closed
October 9, 2019, 7:46am
#3
