[root@av ~]# apachectl -S
[root@av ~]# httpd -S
AH00534: httpd: Configuration error: No MPM loaded.
Here is apache service used by my software:
How about:
netstat -pant |grep -E '\:80|\:443|apache|http'
And this file:
[root@av ~]# netstat -pant |grep -E '\:80|\:443|apache|http'
tcp6 0 0 :::443 :::* LISTEN 19253/httpd
Problems:
Please show the config file.
you mean that _httpd.conf file
Here is the config file:
httpd config 22Dec2020.txt (15.5 KB)
Please show this included file:
Include /usr/local/active/common/web/conf/httpd/httpd_av_prefix.conf
So far:
Listen 443
AliasMatch ^/vault/archive/admin_img(.*) /usr/local/active/vault/web/webapps/htdocs/admin_img/$1
AliasMatch ^/vault/archive/(.*) /usr/local/active/vault/web/webapps/htdocs/archive/index.igm/$1
Alias /vault/ /usr/local/active/vault/web/webapps/htdocs/
<Directory "/usr/local/active/vault/web/webapps/htdocs/">
Options +FollowSymLinks -Indexes
<IfVersion < 2.4>
Order allow,deny
Allow from all
</IfVersion>
<IfVersion >= 2.4>
Require all granted
</IfVersion>
Header set X-Robots-Tag "noindex,nofollow,noarchive"
</Directory>
You disabled including vhosts:
# Virtual hosts
#Include /usr/local/active/common/web/conf/httpd/extra/httpd-vhosts.conf
The config has not enough configured to serve anything on any port.
So i just remove # before command?
Virtual hosts
And add port 80 in config file?
I can't tell you what to do.
I can only show you why it doesn't do anything.
It worked with the previous Apache.
You were able to get a cert with it.
Then you removed that Apache and replaced it with another Apache.
Now this one can't get a cert.
But it can't even serve any content at all.
You need to fix that - you must have a working config before asking for a cert.
Hi rg305,
I already fixed this problem
Currently my website can access by SSL.
I found that Certbot does not support the custom Apache version.
So I temporary disable custom Apache and install standard Apache for renew SSL.
Finally it working
You should be able to use the other apache with --webroot option (not native --apache option).
Once you have switched back to using the new apache, you can then do a --webroot test renewal using --dry-run option.
