Again issue renew my certs on my VM
I need help renewing my certs on my VM running on ubuntu server.
I tried everything but now im lost.
Thanks.
My domains are:
www.peritia-itc.de and www.kgs-web.de
certbot -v renew --dry-run
"certbot --webroot -w /var/www/html/presentation certonly -d www.peritia-itc.de"
"certbot certonly --webroot --cert-name www.peritia-itc.de -w /var/www/html/presentation -d www.peritia-itc.de"
The first command produced the following output:
Failed to renew certificate www.peritia-itc.de with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/www.peritia-itc.de/fullchain.pem (failure)
Apache/2.4.58 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 24.04.2 LTS
My hosting provider, if applicable, is: Strato
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
from let's debug result:
www.peritia-itc.de has an A (IPv4) record (85.88.29.82) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://www.peritia-itc.de/.well-known/acme-challenge/letsdebug-test": dial tcp 85.88.29.82:80: connect: connection refused
looks like they closed port 80 for some reason.
you may want to apache's mod_md module to use tls-alpn challange for it
Adding more evidence to that
$ nmap -Pn -p80,443 www.kgs-web.de
Starting Nmap 7.94SVN ( https://nmap.org ) at 2025-05-31 23:25 UTC
Nmap scan report for www.kgs-web.de (85.88.29.82)
Host is up (0.17s latency).
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp open   https
Nmap done: 1 IP address (1 host up) scanned in 1.41 seconds
$ nmap -Pn -p80,443 www.peritia-itc.de
Starting Nmap 7.94SVN ( https://nmap.org ) at 2025-05-31 23:26 UTC
Nmap scan report for www.peritia-itc.de (85.88.29.82)
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp open   https
Nmap done: 1 IP address (1 host up) scanned in 1.59 seconds
Good afternoon,
thank you for your support.
Problem solved. Certs renewed.
Best regards
Mo
