After certbot renew all certificates are not secute
My domain is: www.projekt-hirnfrei[.]de
I ran this command: sudo certbot renew
It produced this output: success
My web server is (include version): Apache/2.4.57 (Unix)
The operating system my web server runs on is (include version): Arch Linux
My hosting provider, if applicable, is: Contabo
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
After using sudo certbot renew all sites are insecure. I use this server for a long time and never i had a problem with renew the certificates. I try certbot certonly and generate new certificates. Restart apache and server failed.
What can I do?
What's wrong?
https://www.projekt-hirnfrei[.]de works OK for me, has a valid certificate.
There is a separate issue that your site is listed as unsafe by Google Safe Browsing (Google Transparency Report), but this has nothing to do with your SSL certificate.
Hi @diabolus, and welcome to the LE community forum :slight_smile:
Let's start with the output of:
sudo apachectl -t -D DUMP_VHOSTS
Please follow rg305 instructions but also quit getting more certs. You are almost rate limited if not already. I see 4 certs issued today for that name (you only get 5/week and sometimes the logs are late reporting them)
Oh I see. Thats not good. What can I do to remove my site?
You'll have to use the Google tools to identify what's wrong, fix it, and request a removal. Starting here is maybe a good idea: Security Issues report - Search Console Help
This isn't something we can help you with on this forum.
