[root@HMFR-4 conf.d]# certbot renew --dry-run -v --installer null --no-directory-hooks --pre-hook “systemctl stop httpd”
File “/usr/lib/python2.7/site-packages/certbot/plugins/standalone.py”, line 78, in run
raise errors.StandaloneBindError(error, port)
StandaloneBindError: Problem binding to port 80: Could not bind to IPv4 or IPv6.
/etc/letsencrypt/live/merchant.priceblaze.pk/fullchain.pem (failure)
/etc/letsencrypt/live/admin.priceblaze.pk/fullchain.pem (failure)
/etc/letsencrypt/live/www.priceblaze.pk/fullchain.pem (failure)
Running post-hook command: systemctl start httpd
Exiting abnormally:
File “/usr/bin/certbot”, line 9, in
load_entry_point(‘certbot==0.29.1’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1352, in main
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1259, in renew
renewal.handle_renewal_request(config)
File “/usr/lib/python2.7/site-packages/certbot/renewal.py”, line 457, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 3 renew failure(s), 0 parse failure(s)
Domain: merchant.priceblaze.pk
Detail: Invalid response from
http://merchant.priceblaze.pk/.well-known/acme-challenge/dBnw26q6lg9wAsCEBfErP6SUODBitA3-_5_eZF-QRfc:
“\n\n404 Not
Found\n\nNot Found
\n<p”To fix these errors, please make sure that your domain name was
