Acme-v02.api.letsencrypt.org sends RST right after connecting
Do you have a working https site on your server you can share a domain for? That way we can review the tls cipher suite it's currently likely to be trying.
@webprofusion Yes, you can try this one: https://www.tiplon.hr/.
Although, I don't see the point, since connection drops before any data is transmitted. Here is the Wireshark trace:
https://shop.elsam.hr/172.65.32.248f.zip
Thanks, sorry I'm out of ideas. Yes the Wireshark capture looks like Let's Encrypt are forcibly disconnecting. Does outgoing TCP traffic definitely leave your network as the public IP 212.92.212.115 ? Could it be another IP? Does googling "whats my ip" from the server desktop return the expected result?
Public IP is 212.92.212.115, confirmed. https://www.showmyip.com/
Please show the output of:
openssl s_client -connect 172.65.32.248:443
[assuming you have (or can get) openssl for Windows]
This is where I get OpenSSL for Windows.
Useless, connection drops immediately. Check the trace from Wireshark ("handshake has read 0 bytes").
CONNECTED(00000154)
write:errno=10054
no peer certificate available
SSL handshake has read 0 bytes and written 0 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Please show a trace route:
tracert -d acme-v02.api.letsencrypt.org
Tracing route to ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com [172.65.32.248]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.0.20.1
  2     *        *        *     Request timed out.
  3     1 ms     1 ms     1 ms  10.127.105.54
  4     1 ms     1 ms     1 ms  213.147.96.78
  5     1 ms     1 ms     1 ms  213.147.96.77
  6     1 ms     1 ms     1 ms  83.139.120.25
  7     1 ms     1 ms     1 ms  185.1.87.115
  8     1 ms     1 ms     1 ms  172.65.32.248
Trace complete.
I managed to renew certificates using other IP address. However, the problem is still here. Could someone please double-check if this IP (212.92.212.115) is blocked somehow?
I can ping it from 2 different locations
$ ping 212.92.212.115
PING 212.92.212.115 (212.92.212.115): 56 data bytes
64 bytes from 212.92.212.115: icmp_seq=0 ttl=27 time=186.793 ms
64 bytes from 212.92.212.115: icmp_seq=1 ttl=27 time=184.490 ms
64 bytes from 212.92.212.115: icmp_seq=2 ttl=27 time=180.419 ms
64 bytes from 212.92.212.115: icmp_seq=3 ttl=27 time=183.242 ms
^C
--- 212.92.212.115 ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 180.419/183.736/186.793/2.300 ms
Mostly pingable with Check report was removed: Check host - online website monitoring
http accessible Check report was removed: Check host - online website monitoring
https not accessible Check report was removed: Check host - online website monitoring
172.65.32.248 is cloudflare ip but it does send RST right after connect.
dead CF datacenter maybe?
looks like it geoblocked anything outside NA and EU or so
@lestaff cf reverse proxy ip given for acme-v02.api (172.65.32.248) points to broken cf webserver(tcp reset) in APEC region, or wrong geoblocking rule. tested and confirmed broken in (hk,sg,jp,sk) can you hit CF people to reassign a new reverse proxy address for us?
+1, I have a customer who is having a similar issue from Bangladesh.
Fine for me in APAC (Australia) though.
Cloudflare uses Anycast PoPs so the IP alone isn't much help -- that's what it resolves to for everyone.
If I could the output of https://www.cloudflare.com/cdn-cgi/trace that would help with talking to Cloudflare.
Is there a CLI version of this data for headless servers? Like the /cdn-cgi/trace from their HTTP proxy product? I don't think I can easily ask for this information.
https://www.cloudflare.com/cdn-cgi/trace would be helpful; I think it should be the same pops either way.
Thanks, I'll get that info. One affected client IP is: 192.144.82.200.
Can't connect to www.cloudflare.com. Same like acme-v02.api.letsencrypt.org, RST after connecting.
Thanks. That definitely seems like this is some kind of problem on Cloudflare. I'll update this thread with whatever I get back from them.
