@Yuri1 I’m happy that you finally were able to renew, using certbot
. Potentially, the problem was in the fact that you omitted asterisk in your acme.sh-based renew command above (I doubt that it’s valid to use -d .psychiatr.ru
instead of expected -d *.psychiatr.ru
or '*.psychiatr.ru'
; IMO, this is supported by the fact that LE recognizes the request as for multi-domain cert, but not wildcard one – see debug output). Anyway, hopefully, @Neilpang will soon clarify on this (since I quite like acme.sh - thank you for your work, @Neilpang, and would prefer to stay with it versus switching to other ACME client options).
fixed. please try again with the latest code:
acme.sh --upgrade
The reason is that you used dns manual mode first, but you didn’t pass the verification next. The previous txt value was cached by acme.sh.
I just cleared the cache if the verification is failed. So, you will get a new record next time.
Personally, I would suggest you not use dns manual mode.
please consider using dns api mode for dns alias mode instead.
done.
Thanks.
Now it works, thank you!
