Acme.sh - chown: changing ownership not permitted
I want to install Nextcloud and OnlyOffice on a home server and secure both with SSL. I want to be able to reach Nextcloud at https://mydomain.de and Onlyoffice at https://office.mydomain.de. I have already applied for, received and installed the certificate for mydomain.de with acme.sh.
Since three days I am trying to get the certificate for the subdomain office.mydomain.de. - Ok, at night I have slept ;-).
I start the script acme.sh with the user account “acmeuser” with the following call
acme.sh --debug --issue -d office.mydomain.de --keylength 4096 -w /var/www/letsencrypt --key-file /etc/letsencrypt/rsa-certs/privkey.pem --ca-file /etc/letsencrypt/rsa-certs/chain.pem --cert-file /etc/letsencrypt/rsa-certs/cert.pem --fullchain-file /etc/letsencrypt/rsa-certs/fullchain.pem
The script is starting, gets a token, and writes it to /var/www/letsencrypt. But when it is trying to change the owner and group of the token, I get the following error message:
Changing owner/group of .well-known to www-data:www-data
chown: changing ownership of '/var/www/letsencrypt/.well-known/acme-challenge/sQmOWXmtDUB3g_klqNxfkIMG5uRrn2QGMurbnHvLc5s': Operation not permitted
The account “acmeuser” is member of the group “www-data” who is owner of the directory /var/www/letsencrypt.
root@mydomain:/var/www/letsencrypt/.well-known/acme-challenge# ls -l
-rw-rw-r-- 1 acmeuser acmeuser 87 Jan 14 17:52 sQmOWXmtDUB3g_klqNxfkIMG5uRrn2QGMurbnHvLc5s
These are the diagnostic informations:
openssl:openssl
OpenSSL 1.1.1c  28 May 2019
apache:
apache doesn't exists.
nginx:
nginx version: nginx/1.16.1 (Ubuntu)
built with OpenSSL 1.1.1c  28 May 2019
TLS SNI support enabled
configure arguments: --with-cc-opt='-g -O2 -fdebug-prefix-map=/build/nginx-dvyH9w/nginx-1.16.1=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -Wdate-time -D_FORTIFY_SOURCE=2' --with-ld-opt='-Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -fPIC' --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --modules-path=/usr/lib/nginx/modules --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-debug --with-compat --with-pcre-jit --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_auth_request_module --with-http_v2_module --with-http_dav_module --with-http_slice_module --with-threads --with-http_addition_module --with-http_flv_module --with-http_geoip_module=dynamic --with-http_gunzip_module --with-http_gzip_static_module --with-http_image_filter_module=dynamic --with-http_mp4_module --with-http_perl_module=dynamic --with-http_random_index_module --with-http_secure_link_module --with-http_sub_module --with-http_xslt_module=dynamic --with-mail=dynamic --with-mail_ssl_module --with-stream=dynamic --with-stream_ssl_module --with-stream_ssl_preread_module --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-headers-more-filter --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-auth-pam --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-cache-purge --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-dav-ext --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-ndk --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-echo --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-fancyindex --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/nchan --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-lua --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/rtmp --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-uploadprogress --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-upstream-fair --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-subs-filter --add-dynamic-module=/build/nginx-dvyH9w/nginx-1.16.1/debian/modules/http-geoip2
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
Usage:
socat [options] <bi-address> <bi-address>
   options:
      -V     print version and feature information to stdout, and exit
      -h|-?  print a help text describing command line options and addresses
      -hh    like -h, plus a list of all common address option names
      -hhh   like -hh, plus a list of all available address option names
      -d     increase verbosity (use up to 4 times; 2 are recommended)
      -D     analyze file descriptors before loop
      -ly[facility]  log to syslog, using facility (default is daemon)
      -lf<logfile>   log to file
      -ls            log to stderr (default if no other log)
      -lm[facility]  mixed log mode (stderr during initialization, then syslog)
      -lp<progname>  set the program name used for logging
      -lu            use microseconds for logging timestamps
      -lh            add hostname to log messages
      -v     verbose data traffic, text
      -x     verbose data traffic, hexadecimal
      -b<size_t>     set data buffer size (8192)
      -s     sloppy (continue on error)
      -t<timeout>    wait seconds before closing second channel
      -T<timeout>    total inactivity timeout in seconds
      -u     unidirectional mode (left to right)
      -U     unidirectional mode (right to left)
      -g     do not check option groups
      -L <lockfile>  try to obtain lock, or fail
      -W <lockfile>  try to obtain lock, or wait
      -4     prefer IPv4 if version is not explicitly specified
      -6     prefer IPv6 if version is not explicitly specified
   bi-address:
      pipe[,<opts>]     groups=FD,FIFO
      <single-address>!!<single-address>
      <single-address>
   single-address:
      <address-head>[,<opts>]
   address-head:
      abstract-client:<filename>        groups=FD,SOCKET,RETRY,UNIX
      abstract-connect:<filename>       groups=FD,SOCKET,RETRY,UNIX
      abstract-listen:<filename>        groups=FD,SOCKET,LISTEN,CHILD,RETRY,UNIX
      abstract-recv:<filename>  groups=FD,SOCKET,RETRY,UNIX
      abstract-recvfrom:<filename>      groups=FD,SOCKET,CHILD,RETRY,UNIX
      abstract-sendto:<filename>        groups=FD,SOCKET,RETRY,UNIX
      create:<filename> groups=FD,REG,NAMED
      exec:<command-line>       groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
      fd:<num>  groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
      gopen:<filename>  groups=FD,FIFO,CHR,BLK,REG,SOCKET,NAMED,OPEN,TERMIOS,UNIX
      interface:<interface>     groups=FD,SOCKET
      ip-datagram:<host>:<protocol>     groups=FD,SOCKET,RANGE,IP4,IP6
      ip-recv:<protocol>        groups=FD,SOCKET,RANGE,IP4,IP6
      ip-recvfrom:<protocol>    groups=FD,SOCKET,CHILD,RANGE,IP4,IP6
      ip-sendto:<host>:<protocol>       groups=FD,SOCKET,IP4,IP6
      ip4-datagram:<host>:<protocol>    groups=FD,SOCKET,RANGE,IP4
      ip4-recv:<protocol>       groups=FD,SOCKET,RANGE,IP4
      ip4-recvfrom:<protocol>   groups=FD,SOCKET,CHILD,RANGE,IP4
      ip4-sendto:<host>:<protocol>      groups=FD,SOCKET,IP4
      ip6-datagram:<host>:<protocol>    groups=FD,SOCKET,RANGE,IP6
      ip6-recv:<protocol>       groups=FD,SOCKET,RANGE,IP6
      ip6-recvfrom:<protocol>   groups=FD,SOCKET,CHILD,RANGE,IP6
      ip6-sendto:<host>:<protocol>      groups=FD,SOCKET,IP6
      open:<filename>   groups=FD,FIFO,CHR,BLK,REG,NAMED,OPEN,TERMIOS
      openssl:<host>:<port>     groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,OPENSSL
      openssl-listen:<port>     groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP,OPENSSL
      pipe:<filename>   groups=FD,FIFO,NAMED,OPEN
      proxy:<proxy-server>:<host>:<port>        groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,HTTP
      pty       groups=FD,NAMED,TERMIOS,PTY
      sctp-connect:<host>:<port>        groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,SCTP
      sctp-listen:<port>        groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,SCTP
      sctp4-connect:<host>:<port>       groups=FD,SOCKET,CHILD,RETRY,IP4,SCTP
      sctp4-listen:<port>       groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,SCTP
      sctp6-connect:<host>:<port>       groups=FD,SOCKET,CHILD,RETRY,IP6,SCTP
      sctp6-listen:<port>       groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,SCTP
      socket-connect:<domain>:<protocol>:<remote-address>       groups=FD,SOCKET,CHILD,RETRY
      socket-datagram:<domain>:<type>:<protocol>:<remote-address>       groups=FD,SOCKET,RANGE
      socket-listen:<domain>:<protocol>:<local-address> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE
      socket-recv:<domain>:<type>:<protocol>:<local-address>    groups=FD,SOCKET,RANGE
      socket-recvfrom:<domain>:<type>:<protocol>:<local-address>        groups=FD,SOCKET,CHILD,RANGE
      socket-sendto:<domain>:<type>:<protocol>:<remote-address> groups=FD,SOCKET
      socks4:<socks-server>:<host>:<port>       groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
      socks4a:<socks-server>:<host>:<port>      groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
      stderr    groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
      stdin     groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
      stdio     groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
      stdout    groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
      system:<shell-command>    groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
      tcp-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP
      tcp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP
      tcp4-connect:<host>:<port>        groups=FD,SOCKET,CHILD,RETRY,IP4,TCP
      tcp4-listen:<port>        groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,TCP
      tcp6-connect:<host>:<port>        groups=FD,SOCKET,CHILD,RETRY,IP6,TCP
      tcp6-listen:<port>        groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,TCP
      tun[:<ip-addr>/<bits>]    groups=FD,CHR,NAMED,OPEN,INTERFACE
      udp-connect:<host>:<port> groups=FD,SOCKET,IP4,IP6,UDP
      udp-datagram:<host>:<port>        groups=FD,SOCKET,RANGE,IP4,IP6,UDP
      udp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,IP6,UDP
      udp-recv:<port>   groups=FD,SOCKET,RANGE,IP4,IP6,UDP
      udp-recvfrom:<port>       groups=FD,SOCKET,CHILD,RANGE,IP4,IP6,UDP
      udp-sendto:<host>:<port>  groups=FD,SOCKET,IP4,IP6,UDP
      udp4-connect:<host>:<port>        groups=FD,SOCKET,IP4,UDP
      udp4-datagram:<remote-address>:<port>     groups=FD,SOCKET,RANGE,IP4,UDP
      udp4-listen:<port>        groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,UDP
      udp4-recv:<port>  groups=FD,SOCKET,RANGE,IP4,UDP
      udp4-recvfrom:<host>:<port>       groups=FD,SOCKET,CHILD,RANGE,IP4,UDP
      udp4-sendto:<host>:<port> groups=FD,SOCKET,IP4,UDP
      udp6-connect:<host>:<port>        groups=FD,SOCKET,IP6,UDP
      udp6-datagram:<host>:<port>       groups=FD,SOCKET,RANGE,IP6,UDP
      udp6-listen:<port>        groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP6,UDP
      udp6-recv:<port>  groups=FD,SOCKET,RANGE,IP6,UDP
      udp6-recvfrom:<port>      groups=FD,SOCKET,CHILD,RANGE,IP6,UDP
      udp6-sendto:<host>:<port> groups=FD,SOCKET,IP6,UDP
      unix-client:<filename>    groups=FD,SOCKET,NAMED,RETRY,UNIX
      unix-connect:<filename>   groups=FD,SOCKET,NAMED,RETRY,UNIX
      unix-listen:<filename>    groups=FD,SOCKET,NAMED,LISTEN,CHILD,RETRY,UNIX
      unix-recv:<filename>      groups=FD,SOCKET,NAMED,RETRY,UNIX
      unix-recvfrom:<filename>  groups=FD,SOCKET,NAMED,CHILD,RETRY,UNIX
      unix-sendto:<filename>    groups=FD,SOCKET,NAMED,RETRY,UNIX
I would welcome any advice.
Kind regards,
Michael
It looks like there’s some issue history relating to this, but it doesn’t look like anything was done to make this kind of multi-user scenario work with webroot mode.
What webserver do you use? Maybe there’s another mode that would suit you better.
I’m using nginx. I have already read the issue you mentioned and also tried to adapt the proposal kevinoid made: https://github.com/kevinoid/acme.sh/commit/6cebfe5c0940076ccaab11d148ebc38a39f273a7 .
But unfortunately I just got another error:
office.mydomain.de:Verify error:Invalid response from http://office.mydomain.de/.well-known/acme-challenge/5f_YE0hrPgUTDiYAMlMa3Wt7N92u_5ozQ-nl8Z7KaVk
Maybe it has something to do with the fact, that the domain office.mydomain.de is just rechable via IPv6?
A v6-only domain should not pose any problems. It should just work, but of course it’s hard to conclude anything from a redacted domain.
With acme.sh+nginx there’s also something called stateless mode, which has zero moving parts. If you have concerns about privileges and permissions, it’s pretty neat.
